Results 1 to 7 of 7
    Jan 2007
    how much rake on merc cleaver
    Would any one know how much rake the smaller mercury 13 spline cleavers to suit 40/60 hp motors have?
    thanks
    try this.
    might help you find what you want to know...
    0 DEGREE SMALL HUB --
    Used on outboards and I/O's. Produced by all manufacturers. Common pitch range 8 through 13 pitch. Application:
    OMC 10 HP through 100 HP pin drive
    PJ 19 series, PJ 32 series, PJ 75 series
    2 DEGREE FORWARD RAKE --
    Usually wide blade propellers, 14 and 15" diameter. Right hand and left hand rotation. Various manufacturers. Common pitch range 14 through 22 pitch. Application:
    Volvo Penta 270 series out drives
    Volvo Penta 814629
    SMC 342 series
    5 DEGREE AFT RAKE
    -- Mercruiser Black Max Series
    48-78112-11 11 pitch
    48-78114-13 13 pitch
    6 DEGREE AFT RAKE
    -- Ellis inboards
    8 DEGREE AFT RAKE -- Used on Mercruiser wide blade propellers and Mercury outboards through 1979. Common pitch range is 11 through 23 pitch, right hand rotation. The TR215 Mercruiser III drives also have this rake, but a larger series pitch block would be used. (#150 series) Right hand and left hand rotation.
    DYMEX - Inboard blocks available.
    13X12LH 15X16RH 17X17RH 19X18RH
    14X14LH 16X15RH 18X20LH 19X21LH
    15X16LH 17X17LH 19X18LH
    10 DEGREE AFT RAKE (small hub) -- Used on various outboards such as Mercury and Yamaha through 70 HP. Very common on pontoon boats where prop has wide blade design. Pitch range is 9 through 13 pitch, right hand rotation.
    11 DEGREE AFT RAKE -- Used on outboard and I/O propellers, various manufacturers. Mercury propellers manufactured from 1979 and later, 70 HP through the wide blade Mercruisers. Pitch range is 11 through 23 pitch.
    14 DEGREE AFT RAKE -- New style Mercury outboard, with wide blade design. Propeller usually one inch in pitch than they are marked. Horse power range 35 through 70 HP. 48-816702A40 12R14
    48-816704A40 13R14
    48-816706A40 14R14
    15 DEGREE PROGRESSIVE PITCH -- Used on Mercury outboards, 35 HP through 140 HP. Usually have a 3 inch progressive pitch. Stainless steel and aluminum propellers.
    PROP NO.
    RPT NO.
    48-73132-10> 10R15PP
    48-73134-12 12R15PP
    48-73136-13 13R15PP
    48-73138-14 14R15PP
    48-77344-17 17R15PP
    48-77346-19 19R15PP
    48-77348-21 21R15PP
    16 DEGREE AFT RAKE
    -- All manufacturers. Common pitch range is 11 through 25 pitch, right hand and left hand rotation.
    BLACK MAX ALUMINUM -- Used on outboards and I/O's, 150 HP and up. Mercury, Michigan, and Propco style propellers for Black Max motors. These propellers are regressive pitched from the hub to the outer tip.
    PROP NO.
    RPT NO.
    PITCH
    RAKE
    48-78112-11
    11RBM
    05 DEG
    48-78114-13
    13RBM
    05 DEG
    48-78116-15
    15R11
    11 DEG
    48-78118-17
    17RBMAL
    16 DEG
    48-78120-19
    19RBMAL
    16 DEG
    48-78122-21
    21RBMAL
    16 DEG
    48-78124-23
    23R16
    16 DEG
    48-78124-23
    23R11
    11 DEG
    BLACK MAX STAINLESS
    -- These propellers have a higher rake design with a 3 inch progressive pitch. Mercury design used on outboards and I/O's, right hand and left hand rotation.
    PROP NO
    RPT NO.
    RAKE
    48-16312-15
    15RBM
    16 DEG
    48-16314-17
    17RBM
    18 DEG
    48-16315-17
    17LBM
    18 DEG
    48-16316-19
    19RBM
    20 DEG
    48-16317-19
    19LBM
    20 DEG
    48-16318-21
    21RBM
    20 DEG
    48-16319-21
    21LBM
    20 DEG
    48-16320-23
    23RBM
    16 DEG
    48-16321-23
    23LBM
    16 DEG
    20 DEGREE AFT RAKE
    -- Used on outboard and I/O'S, various manufacturers. OMC uses this design for aluminum, SST, and Viper props from 25 HP through the V-6 Cobra through hub exhaust. Common pitch range is 9 pitch through 23 pitch, right hand rotation, and 15 through 23 pitch , left hand rotation. This style propeller also used on the Volvo SX drives. (COBRA SERIES)
    23 DEGREE AFT RAKE -- Used on OMC 70 HP 3 cylinder, OMC V-4 and OMC V-6. This design is not as common as the 20 degree aft rake.
    NEW STYLE OMC V-4 PROPELLERS -- Introduced in the Fall of 1994. All propellers have a 14" diameter and a 2" regressive pitch. These propellers also have a high skew blade design.
    PROP NO.
    RPT NO.
    PITCH
    RAKE
    176214
    17R21 COBRA
    21 DEG
    176215
    19R19 COBRA
    19 DEG
    176216
    21R16 COBRA
    16 DEG
    MICHIGAN REPLACEMENT PROPELLER (MRP) --
    Michigan wide blade propeller for Mercruisers. Available in aluminum and stainless steel. These propellers have a 3 degree aft rake and a 3" regressive pitch.
    PROP NO.
    DIAMETER
    PITCH
    AFT RAKE
    RPT NO.
    SMC374C
    16-0/0"
    3 DEG
    15RMRP
    SMC376C
    15-3/4"
    3 DEG
    17RMRP
    SMC378C
    15-1/2"
    3 DEG
    19RMRP
    SMC380C
    15-1/4"
    3 DEG
    21RMRP
    CHRYSLER FORCE
    -- Semi clever blade design, 2" progressive pitch and a parabolic rake of 12 to 14 degrees. Thru hub exhaust. Available in aluminum or stainless steel.
    PROP NO.
    DIAMETER
    PITCH
    RPT NO.
    FP692
    13-1/2
    15RFORCE
    FP685
    13-1/2
    17RFORCE
    FP686
    19RFORCE
    FP694
    12-5/8
    21RFORCE
    FORCE/CHRYSLER --
    Round ear, non thru hub exhaust. These propellers have a 3" progressive pitch and a 25 degree parabolic rake. 70 HP through 140 HP, stainless steel and aluminum.
    MICH. NO.
    FORCE NO.
    DIAMETER
    RPT NO.
    SPC180
    PS623
    13-1/4
    17RSUPER
    SPC182
    PS625
    19RSUPER
    SPC184
    PS526
    21RSUPER
    INLINE QSS I88 --
    These propellers have a 2" progressive pitch with a 20 to 26 degree parabolic rake. Used for the 75 through 140 HP outboards.
    PROP NO.
    DIAMETER
    PITCH
    RPT NO.
    48-17314-14
    13-3/8
    14RI88
    48-16986-16
    13-1/8
    16RI88
    48-16988-18
    18RI88
    VOLVO APPLICATIONS
    VOLVO 280 & 290 SERIES -- These propellers have an extremely large blade area, with an 8 degree parabolic rake. (NO. 150 SERIES)
    PROP NO.
    DIAMETER
    PITCH
    RPT NO.
    9LPV
    851036-4
    13RPV*
    854986-7
    13LPV*
    872001-3
    15RPV*
    854987-5
    15LPV*
    851125-5
    17RPV
    851124-8
    17LPV
    850865-7
    19RPV
    850864-0
    19LPV
    850867-3
    21RPV
    850866-5
    21LPV
    VOLVO DUO PROPS -
    Propellers available for diesel engines (A series), and gas engines (B series).
    A SERIES
    PROP NO.
    DIAMETER
    RPT NO.
    852249
    13-5/8
    VOLVODUOA1R
    852247
    15-5/8
    VOLVODUOA1L
    854785
    13-3/4
    VOLVODUOA2R
    854775
    15-5/8
    VOLVODUOA2L
    854786
    VOLVODUOA3R
    854776
    15-5/8
    VOLVODUOA3L
    852237
    14-1/8
    VOLVODUOA4R
    852235
    15-5/8
    VOLVODUOA4L
    854789
    14-1/4
    VOLVODUOA6R
    854779
    15-1/4
    VOLVODUOA6L
    B SERIES
    PROP NO.
    DIAMETER
    RPT NO.
    853621
    12-7/8
    VOLVODUOB1R
    853611
    14-1/2
    VOLVODUOB1L
    853622
    13-1/4
    VOLVODUOB2R
    853612
    14-1/2
    VOLVODUOB2L
    854832
    13-1/2
    VOLVODUOB3R
    854824
    VOLVODUOB3L
    853624
    13-3/8
    VOLVODUOB4R
    853614
    14-5/8
    VOLVODUOB4L
    854834
    VOLVODUOB5R
    854826
    14-1/8
    VOLVODUOB5L
    853626
    12-3/4
    VOLVODUOB6R
    853616
    13-3/4
    VOLVODUOB6L
    854836
    12-5/8
    VOLVODUOB7R
    854828
    13-3/4
    VOLVODUOB7L
    853628
    12-1/2
    VOLVODUOB8R
    853618
    13-5/8
    VOLVODUOB8L
    MIRAGE --
    Used on outboard and Bravo outdrives. Pitch range is 17 thru 25 pitch. Propellers have a parabolic rake from 14 degree (17 pitch) to 25 degree on the highest pitch.
    PROP NO.
    DIAMETER
    PITCH
    RPT NO.
    48-18278-17
    15-1/2
    17RMIRAGE
    48-90159-17
    15-1/2
    17LMIRAGE
    48-13700-19
    15-1/4
    19RMIRAGE
    48-13701-19
    15-1/4
    19LMIRAGE
    48-13702-21
    14-3/4
    21RMIRAGE
    48-13703-21
    14-3/4
    21LMIRAGE
    48-13704-23
    14-5/8
    23RMIRAGE
    48-13705-23
    14-5/8
    23LMIRAGE
    48-13706-25
    14-1/2
    25RMIRAGE
    48-13707-25
    14-1/2
    25LMIRAGE
    48-18280-27
    14-3/8
    27RMIRAGE
    48-18281-27
    14-3/8
    27LMIRAGE
    HI-5 (V-6) --
    These propellers have a 3" progressive pitch and a parabolic rake of 26 to 30 degrees. Used on V-6 outboards and Mercruiser applications.
    PROP NO.
    DIAMETER
    PITCH
    RPT NO.
    48-821154-17
    13-1/2
    17RHI5
    48-815758-19
    13-1/4
    19RHI5
    48-815760-21
    13-1/4
    21RHI5
    48-815762-23
    13-1/4
    23RHI5
    48-816374-25
    13-1/4
    25RHI5
    HI-5 (V-4) --
    These propellers have a 2" progressive pitch and a parabolic rake of 30 degrees. Used on the 75 through 150 HP outboards and XR4 series.
    PROP NO.
    DIAMETER
    PITCH
    RPT NO.
    48-816612-20
    12-3/4
    20RHI5
    48-815744-22
    22RHI5
    48-815746-24
    12-3/4
    24RHI5
    48-815748-26
    12-3/4
    26
    26RHI5
    LASER --
    These propellers have a 3" progressive pitch and a parabolic rake of 20 to 23 degree aft parabolic rake. Used for the V-6 outboard and Mercruiser applications.
    PROP NO.
    DIAMETER
    PITCH
    RPT NO.
    48-11070-21
    14-1/2
    21RLASER
    48-11074-23
    14-1/2
    23RLASER
    48-11078-25
    14-1/2
    25RLASER
    LASER II (V-6) --
    A newer version of the Laser propeller with a 4" progressive pitch and a 26 to 29 degree aft parabolic rake.
    PROP NO.
    DIAMETER
    PITCH
    RPT NO.
    48-16543-19
    19RLASERII
    48-16545-21
    13-7/8
    21RLASERII
    48-16547-23
    13-3/4
    23RLASERII
    48-16549-25
    13-3/4
    25RLASERII
    48-19709-27
    13-3/4
    27RLASERII
    LASER II (XR4) --
    These propellers have a small diameter thru hub barrel with a 4" progressive pitch and a 30 to 33 degree parabolic rake. Used with the XR4 series and the inline motors.
    PROP NO.
    DIAMETER
    PITCH
    RPT NO.
    48-16990-20
    13-1/4
    20RLASERII
    48-16992-22
    13-1/2
    22RLASERII
    48-16994-24
    13-1/2
    24RLASERII
    48-16996-26
    13-1/2
    26
    26RLASERII
    TROPHY (SMALL HUB) --
    These propellers have a 4-1/4" hub size, a 2" progressive pitch and rake reading 28 to 32 degree parabolic rake.
    PROP NO.
    DIAMETER
    PITCH
    RPT NO.
    48-825934
    13-3/4
    21RTROPHY SH
    48-825938
    13-3/4
    23RTROPHY SH
    48-825940
    13-3/4
    24RTROPHY SH
    48-825942
    13-3/4
    25RTROPHY SH
    48-825944
      26
    26RTROPHY SH
    TROPHY (LARGE HUB) --
    These propellers have a 4-3/4 hub size, a 0 to 2" progressive pitch and a 28 to 32 degree parabolic rake.
    PROP NO.
    DIAMETER
    PITCH
    RPT NO.
    48-825904
    21RTROPHY
    48-825908
    23RTROPHY
    48-825910
    24RTROPHY
    48-825912
    25RTROPHY
    48-825914
    26RTROPHY
    TEMPEST --
    These propellers have a 2 to 3" progressive pitch and a 25 to 30 degree parabolic rake.
    PROP NO.
    DIAMETER
    PITCH
    RPT NO.
    48-825864-23
    14-1/2
    23RTEMPEST
    48-825866-25
    14-1/2
    25RTEMPEST
    48-825868-27
    14-1/2
    27RTEMPEST
    CHOPPER --
    These propellers have an over the hub exxhaust with three lugs cast to the forward end of the hub which act as weed cutters. All propellers have a progressive pitch and a 23 to 25 degree parabolic rake. Pitches available: 18, 20, 22, 24, 26, 28, 30 RH
    EXAMPLE: RPT NO. 18RCHOPPER
    BRAVO III -- These propellers have a 2 to 4" progressive pitch and a 6 to 11 degree parabolic rake.
    PROP NO.
    DIAMETER
    PITCH
    RPT NO.
    48-823662-20
    14-2/5
    20RBRIII
    48-823661-20
    20LBRIII
    48-823664-22
    14-1/4
    22RBRIII
    48-823663-22
    15-3/4
    22LBRIII
    48-823666-24
    14-1/4
    24RBRIII
    48-823665-24
    15-1/2
    24LBRIII
    48-823668-26
    26RBRIII
    48-823667-26
    15-1/4
    26
    26LBRIII
    48-823670-28
    13-3/4
    28RBRIII
    48-823669-28
    28LBRIII
    BRAVO II --
    Available in aluminum only. These propellers have a 3 to 4" progressive pitch and an 8 to 15 degree parabolic rake. A general rule - the higher the pitch the higher the rake. A #150 series pitch block is required for these propellers.
    PROP NO.
    DIAMETER
    PITCH
    RPT NO.
    48-18606-11
    1RBRII
    48-18607-11
    11LBRII
    48-18608-13
    19-1/2
    13RBRII
    48-18609-13
    19-1/2
    13LBRII
    48-18610-15
    18-1/4
    15RBRII
    48-18611-15
    18-1/4
    15LBRII
    48-18612-17
    17-3/4
    17RBRII
    48-18613-17
    17-3/4
    17LBRII
    48-18614-19
    17-1/4
    19RBRII
    48-18615-19
    17-1/4
    19LBRII
    48-18616-21
    16-3/4
    21RBRII
    48-18617-21
    16-3/4
    21LBRII
    48-18618-23
    16-1/2
    23RBRII
    48-18619-23
    16-1/2
    23LBRII
    48-18620-25
    16-1/4
    25RBRII
    48-18621-25
    16-1/4
    25LBRII
    HIGH PERFORMANCE APPLICATIONS -- OMC
    RAKER (V-4) -- These propellers have a 2" progressive pitch and a 30 degree parabolic rake.
    PROP NO.
    DIAMETER
    PITCH
    RPT NO.
    394759-20
    13-1/2
    20RRAKERV4
    394760-22
    13-1/2
    22RRAKERV4
    RAKER (V-6) --
    These propellers have been manufactured in straight pitch and progressive pitch and a 28 to 30 degree parabolic rake.
    PROP NO.
    DIAMETER
    PITCH
    RPT NO.
    394752-18
    14-1/2
    18RRAKERV6
    394753-20
    14-1/2
    20RRAKERV6
    394754-22
    14-1/2
    22RRAKERV6
    394755-24
    14-1/2
    24RRAKERV6
    394756-26
    14-1/2
    26
    26RRAKERV6
    394757-28
    14-1/2
    28RRAKERV6
    SHOOTER --
    These four blade stainless steel propellers have a 3" progressive pitch and a 32 degree parabolic rake.
    PROP NO.
    DIAMETER
    PITCH
    RPT NO.
    431717
    13-1/2
    23RSHTR
    431718
    13-1/4
    25RSHTR
    431719
    13-1/4
    27RSHTR
    PRECISION TURBO --
    V-4 and V-6 propellers with a 2 to 3" progressive pitch and a 21 to 25 degree parabolic rake. The pitch blocks Rundquist manufactures for the Turbo propellers will also work to repair the majority of the Stiletto propellers.
    Rake is not the only factor that affects bow lift. I noticed the Chopper has less Rake than a Raker but I think its debatable that the Chopper has at least as much bow lift because of blade area or shape of the blade. It could also be the case that with a Chopper the boat doesnt get any tail lift from the Hub?
  3. Thanks XstreamVking, FMP thanked for this post
    Likes XstreamVking, FMP liked this post
    North Tonawanda, NY
    There is a bit of variance in the various Merc cleavers over the years as to the rake angle. Typically they most often fall into the range of 15-20 degrees aft rake. This is a lot less than choppers, Trophy Plus, etc which are bow lifters. A cleaver is normally considered a stern lifter- or not having as much bow lift as choppers. etc.
    Doug
    Not seen an aft rake merc cleaver. they must look a bit weird.
    North Tonawanda, NY
    Most props have an aft rake- blades angled rearward from the hub. Forward
    raked blades are not for performance props- Doug
    Jan 2007
    Thanks for the replies, I find hi rake cleavers work best on my setup.
    Would a decent prop shop be able to measure rake ?
    thanks
    anyone can easy measure the rake, and if a prop shop cant then walk away to another prop shop..
    just put prop on level surface with blade facing say all the way to you right, take a picture then measure the angle.
    it realy is easy.
  1. Mazco cleaver 32' Fatshaft high rake
    By darkdream in forum Propellers
    Last Post: 08-15-2017, 05:59 PM
  2. Mercury Cleaver Rake; Pitch vs. Angle
    By 4Speed in forum Props, Setup, and Rigging
    Last Post: 03-09-2014, 09:50 AM
  3. SRX rake?
    By STV_Keith in forum Props, Setup, and Rigging
    Last Post: 04-22-2008, 12:21 PM
  4. Cleaver rake question
    By Forkin' Crazy in forum Technical Discussion
    Last Post: 03-10-2004, 04:28 PM
