Results 1 to 6 of 6
Thread: Needle bearing grease
09-11-2017, 08:21 AM #1Member
- Jul 2017
- Elk grove
- 31
I am putting together a mariner 175 HP, with the storm going on in Florida I have no idea when my needle bearing grease will show does anyone no what else I can use. I have read Vasaline will work fine is this true. Anything else out there I can use.
09-11-2017, 09:24 AM #2
2 strok oil IF it will be up and running very soon
09-11-2017, 10:20 AM #3Member
- Jul 2017
- Elk grove
- 31
I need something to hold the needle bearings in place for the wrist pin assembly, my needle bearing are loose not in a cage.
09-11-2017, 10:48 AM #45000 RPM
- Jan 2013
- GA
- 212
- 35
- 10
- 43
- 32
Vaseline will be fine. Will melt out almost immediately.
09-14-2017, 09:03 PM #5
The last time I was in Rite Aid I asked for a box of latex gloves and the biggest jar of vaseline they had I love the look that request gets.
09-14-2017, 10:05 PM #6Member
- Jul 2017
- Elk grove
- 31
Thanks guys you have all been a big help through this process, waiting on reeds than should be able to fire her up.
Needle bearing assembly grease in DFI?
By wingtime in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 16Last Post: 08-17-2016, 03:55 PM -
Boat Trailer Bearing Grease
By 4Speed in forum General Boating DiscussionReplies: 29Last Post: 04-27-2016, 12:33 PM -
Mercury Tech: Needle Bearing Assembly Lube
By sschefer in forum Technical DiscussionReplies: 77Last Post: 03-28-2016, 10:25 PM -
Mercury Tech: Driveshaft lower needle bearing
By kenrod55 in forum Technical DiscussionReplies: 2Last Post: 12-19-2014, 01:06 PM
