Results 1 to 6 of 6
    Jul 2017
    Elk grove
    Needle bearing grease
    I am putting together a mariner 175 HP, with the storm going on in Florida I have no idea when my needle bearing grease will show does anyone no what else I can use. I have read Vasaline will work fine is this true. Anything else out there I can use.
    2 strok oil IF it will be up and running very soon
    Jul 2017
    Elk grove
    I need something to hold the needle bearings in place for the wrist pin assembly, my needle bearing are loose not in a cage.
    GA
    Vaseline will be fine. Will melt out almost immediately.
    The last time I was in Rite Aid I asked for a box of latex gloves and the biggest jar of vaseline they had I love the look that request gets.
  6. Likes sonicss33, AZMIDLYF liked this post
    Jul 2017
    Elk grove
    Thanks guys you have all been a big help through this process, waiting on reeds than should be able to fire her up.
  1. Needle bearing assembly grease in DFI?
    By wingtime in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 08-17-2016, 03:55 PM
  2. Boat Trailer Bearing Grease
    By 4Speed in forum General Boating Discussion
    Last Post: 04-27-2016, 12:33 PM
  3. Mercury Tech: Needle Bearing Assembly Lube
    By sschefer in forum Technical Discussion
    Last Post: 03-28-2016, 10:25 PM
  4. Mercury Tech: Driveshaft lower needle bearing
    By kenrod55 in forum Technical Discussion
    Last Post: 12-19-2014, 01:06 PM
