Results 1 to 15 of 36
Thread: Vking yt setup
09-08-2017, 06:28 PM #1
Vking yt setup
Anyone interested in setting up a vking yt with a 300 yamaha? Well ill save you the trouble and time and head ache. I know all boats a different but this can set you in some direction. Just want to say thanks to all the local longisland boating friends in the area for letting me borrow and try all these props. If it wasnt for them i wouldnt be where im at now. The yamaha has 1.75 gears and a limiter at 6150rpm with 5in of setback. I tried 8 different props in the last few weeks. All acted different, some real good and some not so well. The ones i thought to run mint didnt and the ones i thought wouldnt run well they did. Most of these props were ran 1in to 1.25in above pad. All props ran 90-99mph on the limiter. Im waiting on a 15x35p HPD hoss to try and on the hunt for a 35p bravo. So far out of all the props i have tried the 34 bravo1 was the fastest and equal in handling to the 32 promax. Im on the hunt to get a stock bottom vking yt with a stock ecu 300yamaha to run a solid 105 mph. If on limiter after i try the 35hoss ill be sending out the ecu for more revs. Anyone interested in more info message away. I will be updating post as i make morw progress. Enjoy guys and stay fast!
29 trophy...90mph 6150rpm
30 pro et...95mph 6150rpm
30 px5 hydromotive.94mph 6150rpm
31 5blade cutting edge. 98mph 6900
32 et...93 6150rpm
32 promax...95 6150rpm
32 dr4...99 6900rpm
14.5x34 cleaver...92 6150rpm
14.85x34 cleaver 103 6900rpm
34 bravo...102 6150rpm
14.65x35 4blade cleaver...104 6900
35 bravo...104 6150rpm
35 bravo... 111 6900rpm
35 5blade signature...90 6150rpm
16ft superboat
14ft vixan
15ft viper
24ft sleekcraft
21ft sleekcraft modvp
18ft action hst drag
18ft accelerator drag
21ft redline
18ft vking yt
20ft Allison grandsport
20ft laser 420
18ft X-Stream Vking
24ft banana
09-17-2017, 01:30 PM #2
new speed of 102.3mph with the 34p bravo1
16ft superboat
14ft vixan
15ft viper
24ft sleekcraft
21ft redline
18ft vking yt
20ft laser 420
18ft X-Stream Vking
24ft banana
09-17-2017, 02:15 PM #3Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Thru hub props will surprise you sometimes.....I would have never thought my boat would like a tempest 29p...But it does. Congrats on the project being a success.
09-17-2017, 06:46 PM #416ft superboat
14ft vixan
15ft viper
24ft sleekcraft
21ft redline
18ft vking yt
20ft laser 420
18ft X-Stream Vking
24ft banana
09-25-2017, 05:04 PM #5
Trying the 15.25x35 bravo tomorrow morning before work. Low winds. Should be a good morning. Will keep posted
16ft superboat
14ft vixan
15ft viper
24ft sleekcraft
21ft redline
18ft vking yt
20ft laser 420
18ft X-Stream Vking
24ft banana
09-25-2017, 06:44 PM #6
Be safe....Fast Eddie!
09-27-2017, 04:34 AM #7
Thank you for sharing your results. I spotted this boat on Facebook earlier, very cool with the Yamaha!
The posted results should be interpreted with caution when comparing prop types. As all posted props were hitting the limiter, the Bravo might well be the fastest because it was one of the highest pitch props included Not saying that the Bravo isn't a decent prop for this setup, just thinking out loud
Looking forward to any further results
09-27-2017, 11:48 AM #816ft superboat
14ft vixan
15ft viper
24ft sleekcraft
21ft redline
18ft vking yt
20ft laser 420
18ft X-Stream Vking
24ft banana
09-27-2017, 12:00 PM #9
I went out this morning and tried the 35p bravo 1 with a cut barrel. the boat seemed to handled better with the cut barrel then the 34p bravo with the flare on it. I am still on the rev limiter (6150) with the bigger prop.It ran 102mph four passes in a row. The speed is alot more consitant then the 34p. Over all proformance i still say the bravos are a great wheel for this setup. My next prop ill be trying this weekend is a 15x35 hyperdrive hoss brand new. With the bigger blades then the bravo and the design of the prop i believe it should lower my slip rate and push the boat pretty good. This will be the last large prop im going to try on this setup. If by any chance im still on the limiter i will be over winter sending my ecu out to get bump to 6650-6700rpm. Enjoy.
16ft superboat
14ft vixan
15ft viper
24ft sleekcraft
21ft redline
18ft vking yt
20ft laser 420
18ft X-Stream Vking
24ft banana
09-27-2017, 12:22 PM #1016ft superboat
14ft vixan
15ft viper
24ft sleekcraft
21ft redline
18ft vking yt
20ft laser 420
18ft X-Stream Vking
24ft banana
09-27-2017, 12:29 PM #11
Nice Birthday Pass
16ft superboat liked this post
09-29-2017, 01:44 PM #12
So the hoss prop ran pretty damn good. Me and Tim went with the HPD 15x35 to keep me off the limiter and to carry the boat with the heavy 550lb yamaha. Well im off the limiter and just around 101 at 5750-5800rpm which is like 7-8% slip. Im going to try moving some weight around and maybe a little more engine height and setback. Over winter after i run the boat a few more times and document the setup i will be sending the prop back to Hoss for the final adjustments as well as having my ecu flashed by Simon for a few hundred more rpms. Over all performance of the Hoss HPD, its a great wheel and it runs just as stable as the 4blade PROMAX. Great hole shot, im using alot less trim then the other wheels. Thank you Tim Bostic for making one hell of a prop for the stream.
16ft superboat
14ft vixan
15ft viper
24ft sleekcraft
21ft redline
18ft vking yt
20ft laser 420
18ft X-Stream Vking
24ft banana
tux974 liked this post
09-29-2017, 05:29 PM #13Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Any more tq steer with the hyperdrive, compared to the promax?
09-30-2017, 09:05 AM #1416ft superboat
14ft vixan
15ft viper
24ft sleekcraft
21ft redline
18ft vking yt
20ft laser 420
18ft X-Stream Vking
24ft banana
XstreamVking thanked for this posttexasvector liked this post
10-02-2017, 06:16 AM #1516ft superboat
14ft vixan
15ft viper
24ft sleekcraft
21ft redline
18ft vking yt
20ft laser 420
18ft X-Stream Vking
24ft banana
D.ONEAL, OrangeCrush liked this post
vking setup
By bigbluechevy454 in forum Props, Setup, and RiggingReplies: 0Last Post: 05-31-2010, 06:27 PM -
hydrostream vking setup
By bigbluechevy454 in forum Props, Setup, and RiggingReplies: 12Last Post: 05-17-2010, 07:49 PM -
Hydrostream Vking Setup Evinrude 175
By FenceDawg in forum Technical DiscussionReplies: 3Last Post: 05-18-2009, 07:09 PM -
By FenceDawg in forum Technical DiscussionReplies: 3Last Post: 05-11-2009, 07:38 PM -
setup for vking yt ??
By tblotske in forum Props, Setup, and RiggingReplies: 7Last Post: 10-19-2006, 05:30 PM
