Results 1 to 15 of 50
Thread: Merc V-200 87´ deceased or not?
09-07-2017, 03:10 PM #1Member
- Jul 2006
- Karrebaeksminde, Denmark
- 38
- 49
- 49
Hi all
I need some help to dertermine what is wrong inside my motor.
The story goes like this:
During my last ride the engine started making noise (like a blown bearing or something) and stopped. I wasn´t able to start the engine again. After being towed to shore I tried to locate what went wrong.
The engine won´t start now and the starter-motor can turn the engine 2 revolution before getting stuck. The Battery is ok and has turned the starter-motor fine until now. Keep pushing the ignition (starter-motor) will bring the crank past this "dead" point but on if I keep forcing the starter-motor on several times. When the crank gets past this "dead" spot the starter-motor will turn the crank 2 revolutions again before getting stuck again.
I hope this make some kind of sense, if not, please ask and I´ll try to supply you with further details.
What I want to know is:
Is this engine dead or not?
What causes the engine to get stuck after 2 revolutions?
Kind regards
Christian, Denmark
09-07-2017, 03:38 PM #2
You have more than likely stuck a piston. Pull the heads and quit trying to start it. You can only hurt it worse by turning it over.
RockTeam Junk
bimmer1 thanked for this post
09-07-2017, 05:12 PM #3Member
- Jul 2006
- 38
- 49
- 49
09-07-2017, 05:45 PM #4
Good luck.
Team Junk
10-04-2017, 05:29 PM #5Member
- Jul 2006
- 38
- 49
- 49
I´ve located the problem to left bank lower cylinder. The conrod bearing is trashed (pic 4) and small pieces of metal has unfortunately damaged both the piston and the cylinder wall. I am now in the process of disassembling the motor totally and it is going well so far. However, I can´t remove metalring between the flywheel and the crankshaft (pic 5+6). I need to remove that ring in order to remove the black part under that ring. First then can I remove the block and get to pistons, rods etc.
Hoping you can give me a bit of advice both in relation to removing the ring (pic 5+6) and maybe an idea of whether the block can be rebuild or needs a replacement. I asume that the conrod bearing, conrod (maybe) and piston can be replaced.
10-04-2017, 07:53 PM #6
Flywheel puller is needed to remove the hub... no need to remove the 8 bolts to remove the wheel, comes off with the hub!
10-04-2017, 10:35 PM #7
If that bearing is as bad as it looks you are going to need a piston, bearing, rod and crankshaft at a minimum and yes the block can be fixed. If you have a lifting ring you can drill the center and tap it then run a bolt down onto the end of the crank to separate flywheel hub. As stated above you could have left the flywheel in one piece. Good luck.
RockLast edited by rock; 10-04-2017 at 10:39 PM.
Team Junk
10-05-2017, 10:44 AM #8Member
- Jul 2006
- 38
- 49
- 49
10-14-2017, 03:52 PM #9Member
- Jul 2006
- 38
- 49
- 49
I´m having a hard time seperating the Block from the Mid section and would like to ask if there is any tips end trix for this operation.
I´ve removed the 10 Nuts that holds the Block together with the Mid section but the Block is pretty much stuck.
I´m thinking of putting back the Flywheel and the try to get one of those lifting eyes that fits on top/inside the Flywheel. Is that the way or is there another way to loosen the Block from the Mid section?
Regards
10-14-2017, 05:58 PM #10Screaming And Flying!
- Dec 2001
- 9,503
- 270
- 191
- 1975
The long studs get stuck. I use a very flat wedge starting at .005 and going to 1/8 inch.heat the stud area and bang the wedges. A part of leaf spring if ya can't get wedge....
10-15-2017, 12:32 AM #11
Also .Get the lower unit off 1st
10-15-2017, 08:43 AM #12Member
- Jul 2006
- 38
- 49
- 49
11-11-2017, 07:04 PM #13Member
- Jul 2006
- 38
- 49
- 49
Now the motor is pretty much disassembled and I have inspected the Block, Rod, crank, Piston etc.
The piston has small scratches on the sides and some significant nicks on top. The Crank and rod has some damage but I can´t tell if it is possible to repair (if necessary) or not.
The Rod bearing is totally gone. The block has a significant scratch and I hope that the block can somehow be repaired.
Questions:
Which parts needs to be repaired and is it realistic to re-fit some of the old parts?
I know for sure that I need a piston and rings but what about the conrod?
For sure I need a new bearing (the old one isn´t there anymore.
Can the crank be repaired?
I´m planing to replace all piston rings since I have all pistons out of the motor now, good idea?
Is there anything else that you guys would consider replacing now that I have the motor disassebled at this level?
Pictures of the involved parts attached below.
I hope you guys will take a look at the pictures and let me know what you think. Thanks
11-11-2017, 10:29 PM #14
You need a crank, rod, piston and a sleeve...plus the required rebuild parts.
11-12-2017, 12:04 PM #15Member
- Jul 2006
- 38
- 49
- 49
Crank, piston, rod makes sense but I´m not sure how to get the block re sleeved. Are you refering to the chrome bore and can the chrome bore/sleeve be replaced?
merc water pressure gauge part# to match older merc gauges??
By syclone01 in forum General Boating DiscussionReplies: 3Last Post: 09-09-2016, 10:48 PM -
Lifeline jacket, merc manual, merc lifting ring, LU flush adapter
By John S in forum Misc. Parts and AccessoriesReplies: 5Last Post: 07-13-2016, 02:21 PM -
Mercury Tech: 50hp 4cyl Merc vs. 70hp 3cyl Merc vs. ??? - Weight vs HP - Opinions??
By Steve2ManyBoats in forum Technical DiscussionReplies: 6Last Post: 02-22-2016, 07:25 AM -
Dennis Cavanaugh, deceased
By Firestarter in forum General Boating DiscussionReplies: 13Last Post: 10-15-2003, 10:54 AM
