Results 1 to 7 of 7
    Sep 2017
    Oceanside
    Setback and jack plate or no jack plate
    Just got a new deck boat with a 300xs. Looking for some advice on the set up. This is my first outboard and I am slowly figuring it out. I currently have a 10inch set back with a atlas jack plate. Unless the jack plate is all the way down it gets alot of prop wash coming out of the hole. I was thinking about adding a 4 inches to the set back. Also I have been contemplating just ditch the jack plate and put and set paragon back bracket to lose some weight.
    Jun 2002
    Northern Utah
    I guess you mean the prop is slipping by prop wash? Someone here may be able to help you if you provide more info....What prop are you using and what is your center of prop to bottom of pad distance when the plate is all the way down?
    Great looking boat....what is it?
    you said
    "Unless the jack plate is all the way down it gets alot of prop wash coming out of the hole"
    for hole shot it is meant to be all the way down, then raise once its up .
    if the prop was high to start with it WILL slip a lot and give tons of prop wash.
    Jul 2014
    uk
    Interesting point though. Would loosing the weight of the setback gain any speed or would the speed be lost in the setback removal?
    well the setback is there to change centre of gravity I.E move it back further.
    This moving it back allows the front half of the boat to come up a bit more thus causing less wetted area.
    This in turn allows for more speed due to less hull touching the water and boat riding on minimal amount of hull.
    The weight of the setback is minimal... and I would say keeping it makes the boat faster not slower.
    maybe on those particular boats its slower I dont know, but in general its the fast boats that have set backs.
  6. Likes NeedOne liked this post
    Apr 2017
    sachse tx
    i have a 22 foot champion bass boat with a promax 225 efi and a manual 6 inch manual
    because the promax is about 60 lbs lighter i think im a little ass light would a 10 inch make up the difference
    what would be the pro and con
    i ve been having a hard time getting full plane
    Jun 2014
    South Carolina
    Quote Originally Posted by mackmanscott View Post
    I've been testing setbacks on my 19 Gambler.. 6" and 8"
    What phillnjack says above agrees with what I found
    with 8" it likes to fly, 6" it runs wet
  1. jack plate setback on euro 15''
    By Bridgeportmerc in forum Technical Discussion
    Last Post: 07-20-2014, 09:09 PM
  2. Manual Jack Plate with very little setback?
    By JnT in forum Technical Discussion
    Last Post: 06-23-2008, 08:06 AM
