Results 1 to 6 of 6
Thread: 45 SS Water Pump
09-06-2017, 03:23 PM #1Junior Member
- Aug 2012
- To
- 13
45 SS Water Pump
I have a mid 80's 45SS (aka SST45) that had a water pump failure. When I went to remove the Impeller from the I had a heck of a time due to some corrosion on the Drive Shaft. Once i managed to slid it up (after cutting off the rubber) by prying in up the Drive Shaft a sliver of white plastic (lying in front of the shaft in the picture) fell off of the flat on the Drive Shaft (a bit hard to see but just visible in the photo).
I was expecting a key similar to the parts list I'm holding in the photo background.
Has anyone seen this before? What is the fix?
ThxLast edited by jimi1; 09-06-2017 at 03:29 PM.
09-06-2017, 04:16 PM #2Junior Member
- Aug 2012
- To
- 13
Are there plastic keys on some impellers?
09-06-2017, 10:09 PM #35000 RPM
- Jun 2009
- central minnesota
- 770
- 30
- 24
just a newer style regular j/e .what # on that paper-th
09-07-2017, 07:56 AM #4Junior Member
- Aug 2012
- To
- 13
Just checked the replacement pump kit and found the plastic keys. Huh.
Never came across this style before. They have always been keys or splines. Weird part was the part manual showing a key.
This thread is done. Thx
11-13-2017, 09:59 AM #5Junior Member
- Aug 2012
- To
- 13
11-17-2017, 05:24 PM #6Junior Member
- Aug 2012
- To
- 13
Water pump: do you change the housing with every new pump?
By pcrussell50 in forum Technical DiscussionReplies: 2Last Post: 06-01-2017, 06:00 PM -
Outboard jet pump & water pump seal question
By jetriverfish in forum Jet Boats, V-Drives and Stern DrivesReplies: 0Last Post: 09-02-2012, 06:50 PM -
Mercury Tech: mercury 2.4l high water pressure after I installed water pump kit.
By sasquitch in forum Technical DiscussionReplies: 23Last Post: 07-31-2010, 09:16 PM
