Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 16 to 30 of 56
    Jul 2007
    Have lived and worked in New Zealand ,Tahiti,Australia,Japan , south Korea, And now Suzhou in China
    And in this corner......lol
    You know what's annoying, when the toilet paper roll gets installed backwards
    and if you didnt put the roll in that's your problem ! don't blame others !
  2. #17
    Jul 2007
    And so the senseless ranting begins all over again , has nothing to do with what the thread is about but what the hell ! who cares ??
  3. #18
    Jun 2010
    over there a minute ago
    WOW - Who would have ever thought that this thread would come so far off of the tracks that it would morph into toilet paper origami with movie quotes ? outstanding !!!
  4. #19
    Jul 2007
    Quote Originally Posted by capt bart View Post
    Multi functional its called !!pointless and silly but what ever !!
  5. #20
    Quote Originally Posted by tunnels View Post
    LOL , you guys still fighting
  6. #21
    Jun 2010
    Not me , man . I'm just havin fun !!!!
  7. #22
    Jul 2007
    Whew that worked until next time !
  8. #23
    Jun 2010
    bye-bye
  9. #24
    Jul 2007
    I made custom interior and outdoor patio furniture in the 80's from fiberglass, this is nothing new especially in the yachting industry. Sorry, you didn't invent it.
    I have never seen this done ever any where and neither has anyone else so until we have conclusive BEYOND THE SHADOW OF A DOUBT evidence other wise ITS MY INVENTION !!
    Why didn't you think of it ?? its simple !! oops forgot it takes some thinking about to make it work properly !
  10. #25
    Jan 2007
    Amityville/Lindenhurst
    I have hired and worked along guys who have claimed to be the father of some invention, only to show them others use it as well
    Good for you for thinking but dont think others cant think as well, sometimes you are not always the smartest person in the room.
  11. Thanks capt bart thanked for this post
    Likes capt bart, vnemous liked this post
  12. #26
    Dont feed the troll. Now he invented toilet paper, Unbelievable. He probably invented the first use for it too
  13. Likes capt bart liked this post
  14. #27
    Jan 2007
    He invented Linder, who then invented everything
  15. Likes vnemous, capt bart liked this post
  16. #28
    Jul 2007
    Quote Originally Posted by RobF View Post
    what ever!!
    One question not one person has asked is HOW DO YOU GET GEL COATED GLASS TO GO AROUND A CORNER WITH OUT IT CRACKING ?
    Themaking of origami flat and curved panels
    Ok to make this origami folding panel took some thinkingabout HOW to get glass to go round corners and how to elliminate the gel coatcracking and still have a nice shiny glossy finish !
    First a step back wards!!
    Understanding how gel coats works from the moment you pourthe catalyst and begin to mix it !, throught the spray application and then waiting to reach the right time ofthe gelcoats gel stage !!
    Knowing how gel coat goes hard an what is happening duringthat process??.
    Unlike paint that relys on eveaporation or absorbtion ofthiners etc to gradually eveapaorate and or soak to go hard over a long periodof time from the top surface downwards !.
    Gel coat does the exact opposite it hardens from the mouldssurface up towards the top and this was the key to being able to get the fineglass ( will come back to this in a moment ) gently pressed INTO the gel coat yetnot pressing hard enough for the glass filiments to go all way into the softpartially gelled gel coat that would show on the finished out side surface !!
    Glassreinforcing the gel coat as close to the outside surface as possible withoutgoing through is the key to helping elliminate cracking when bending the glassto form a smooth raduised rounded corner!!
    Nowwhat sort of glass should be used and why!!.it needs to be fine and it needs tobe strong , Tissue is not the answerat all !
    Ichose the finest woven cloth I could find we had on site!.usually use as askinning cloth for wooden boats !
    Afterlooking and thinking I decided to make all the glass strands run the longestway possible ,so cut the glass on a 45 degree angle so all the strands wereeffectivly the same length and wouldn’t cause any unsightly fibre print throughin the gel coats surface !!. Again the longstrands are easy to bend across and round the corner with the least amount ofstiffness to go round a curve!!
    Okthat took care of the curved corners, the flat surfaces of the panels were sprayed at the same time sothe normal hardening time is allowed before the first layer of a 450 gram csm glasscut to a exact perfectly straight line where the curve would start from andstepped back a little further the heavyer fabric with csm on top then a corefitted procisly to accomidate for the bending of the corner and not make avisible hard crease where it ended!.
    Careand attention to fine detail cutting and fitting during the wet glassing, Peelply needs to be used to make as smoother transition as possible to anyvariations in thickness of the glass and the resin build ups as this will makeuniform bending impossible!!
    Thecore should be cut at a 30 degree angle not 45!! And the inside laminant on thetop of the core needs to be kept back from the angled cut to give the leastamount of chance of the heavyer glas
    s arlyand glass fibres will press all the way through and show on the outside surfaceagaint the mould !!,
    Allthe resins used during this part needs to be mixed with a good amount of thegel coat to get the deepth of colour and so there will be NO SEE THOUGHSany where !!
    Inever said it was going to be easy!! But the rewards of glossy nicely curvedradiused corners internal or external are well worth the effort!!
    As youbecome more familiar with the whole process so it becomes much easyer andquicker to make!
    Planningthe layout of a whole long panel is crucial and has to be done very accurately toget the right amount of area for each curved corner !
    Thisfar by now you can see many areas where if you don’t know everything aboutresins and gel coats and how uneven thicknesses of mateial can behave withdifferent shrinkage rates and pulling and distorting etc you really can end up with a disaster on your hands .
    Productknowledge is something I am always including in just about everything I write about!!
    Alsothe accurate measuring and mixing of catalysts and hardeners on all resins andgel coats, Getting the timing right and knowing exactly the gel time of the gelcoat !, then mixing resin and rolling the fine glass into the semi gelled gelcoat is critical , catch it to late the glass is not close enough to the moulds surface!!
    I didn't invent it I just saw a way it could be done and took it and made it work !!
  17. #29
    You ask a lot of questions for a guy, I assume your a guy, that knows everything. Again you just ask so you can get your GOTCHA
  18. #30
    Jul 2007
    And what is you chosen profession ?? do you have anything to do with composites or is it just a pastime and a place to pass the time ?
  1. What is the hardest part of laying fibreglass ??
    By tunnels in forum Fiberglass and Composites Discussion
    Last Post: 07-28-2017, 07:48 PM
  2. fibreglass supplier options
    By outasite in forum Fiberglass and Composites Discussion
    Last Post: 02-13-2015, 10:18 AM
  3. Can anyone tell me the name and make of my 1972 Fibreglass sport boat?
    By regrp in forum General Boating Discussion
    Last Post: 08-24-2012, 10:45 PM
  4. Fibreglass repair
    By Burke Kilgour in forum Technical Discussion
    Last Post: 09-24-2001, 03:15 PM
