Results 1 to 4 of 4
08-27-2017, 02:54 AM #1
Making a vee birth with lift out openings
this is very simple to make a vee birth the same concept was used for the floor and the ply moulds for the lift outs were all the same size throughout the whole boat !! ,the ply wood was impregnated with thick coats of release wax !!, also the cored glass lay up was almost identical also! Later the lift out lids were all made from glass and 5 mm core matt and glass . The resin used was pigmented white so being white all through with white gloss top no touch ups required and the thumb holes only needed a find sand ! Pigmented resin is a excellent quick way of making hatch's also and there very little finishing work needs to be done !!AND if you use PEEL PLY and roll that nicely on the underside the finish is even better !!
Have done all these kinds of things all my working life and it just becomes second nature and hardly even have to think about it any more !Last edited by tunnels; 08-27-2017 at 06:59 AM.
08-27-2017, 07:30 AM #2
Very nice.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
08-27-2017, 09:00 AM #3
In South Korea we had lots big flat panels to be made so made a steel frame on wheels and 4 sheets 8x4 mdf board on top tongue and grooved joined then epoxy coated ,sanded and gel coated then sine sanded and polished so could also was able to be used for infusion or vac bagging table !
The vee birth panels were gel coated white and the ply screwed together and waxed then stuck to the mould with double sided tape then coved with models clay all round ! gel coated and then the nida core and glassed and flow coated on the underside ! , A ply pattern made for the actual shape and when de-moulded and flipped right way up marked from the pattern !!, the ply formers were knocked out and set back on the mould for a different shaped panel and the whole process repeated quite a few times , So the cnc was able to cut the fiberglass core matt fiberglass sheet for the drop in lids all the same and interchangeable !Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
09-01-2017, 08:52 AM #4
Again trying to demonstrate that life doesn't have to be complicated and panels and shapes can be made outside the boat , patterns made to cut to and then the final fitting and glassing in place complete with lift outs all pre-moulded and shaped saving many hours of fiddly work !
OMC Tech: Transfer Port Openings 150 Cross Flow
By LSaupe in forum Technical DiscussionReplies: 2Last Post: 04-23-2011, 05:41 AM -
Any openings in St. Pete Area
By J bonz in forum Employment ListingsReplies: 0Last Post: 06-22-2008, 03:13 AM -
My employer has a few openings
By CDave in forum Employment ListingsReplies: 1Last Post: 05-13-2004, 04:22 PM -
List of Job openings where I work
By WharfRat in forum Employment ListingsReplies: 2Last Post: 02-06-2004, 05:31 PM -
Any job openings down south?
By Djyox in forum General Boating DiscussionReplies: 20Last Post: 07-29-2003, 08:07 AM
