Results 1 to 3 of 3
Thread: trim pump
    Apr 2011
    Pierre Part, Louisiana
    trim pump
    I have the single ram trim setup on my xb2003, was wondering if anyone could float me a diagram for wiring the pump and solenoids. I have down trim, when i hit the blinker switch to trim up i have nothing but a click from the pump. Thanks in advance.
    98 SS2000 Comp 2.5 "PRO STOCK" Merc
    92 XB2002 Comp 2.5 280
    Shawano,WI
    After changing my trim to 24V up for a day of Drag racing last weekend I pulled my 2nd battery out and I have/had the same issue, buddy set it up for me. Looks like you need power to both solenoids and you probably only have power to the down though your switch? I took the long wire we added to my second battery and hooked it to my positive on my main battery and mine now works. I originally just had a small jumper between the positives on my solenoids I believe.
    SE MN
Name:	24 volt trim.jpg
  1. Replies: 2
    Last Post: 02-24-2017, 10:21 PM
  2. Racing Trim pump vs regular trim pump
    By Krazymaan in forum General Boating Discussion
    Last Post: 09-13-2016, 09:37 AM
  3. Replies: 7
    Last Post: 11-26-2013, 08:58 PM
