Results 1 to 6 of 6
Thread: Aluminum vs Fiberglass
08-21-2017, 07:21 AM #1Junior Member
- Jan 2014
- AL
- 25
I have an aluminum Xpress X21 powered by a G2 250 HO...I had a Ranger 520c also powered by a G2 250 HO...Both would run low to mid 70s depending upon load and conditions but the X21 is substantially lighter (nearly 300 lbs)...Is it just because of the design of the hull? Is glass more conducive for reaching higher speeds than aluminum? Can there anything be done to my X21 aluminum hull to make it faster?
08-21-2017, 08:45 AM #2
Most all aluminum fishing boats have a depression just before the transom on the bottom caused from sliding over stumps. Heavy motor, thin skin. It creates a speed robbing a hook. Fiberglass boats don`t have this problem. Check you boat bottom.
DB
08-21-2017, 08:46 AM #3Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Those xpress boats are one of the fastest aluminum boats you can get. Very good hulls, and light. Glass however, can be molded in more complex forms and will generally be faster than alum.
blacktruck liked this post
08-21-2017, 09:23 AM #4Junior Member
- Jan 2014
- AL
- 25
Crazy you say that...There is a good sized dent in mine about 2-3' from the transom...Caused from hitting a rock or stump by the previous owner...There is a small hook as I've checked it with a straight edge...What do you recommend to remedy this?
Do you think a flat thru hull transducer (P319) mounted on the bottom of the aluminum would cause much speed loss?
08-22-2017, 05:56 AM #5
A metal shop could fashion some sort of brace inside the hull but then the same thing will happen somewhere else and you can`t put braces everywhere. You would end up with a very heavy boat. This is what the fiberglass boat builders say will keep them in business building boats.
Anything creating drag will cause a speed loss.
DB
08-22-2017, 07:18 AM #6Junior Member
- Jan 2014
- AL
- 25
10-4 thank you
LOOKING for a FIBERGLASS GUY
By DryMartini in forum Appearance ModsReplies: 0Last Post: 06-16-2013, 05:27 PM -
need help LI fiberglass
By 21eagle in forum Fiberglass and Composites DiscussionReplies: 5Last Post: 04-11-2009, 09:55 AM -
i like fiberglass too...
By cranknrods in forum General Boating DiscussionReplies: 15Last Post: 11-12-2006, 06:47 AM -
Fiberglass over gel ?
By Big Johnson v6 in forum Fiberglass and Composites DiscussionReplies: 2Last Post: 08-17-2006, 12:57 PM -
how to get into fiberglass
By Fibertron in forum Fiberglass and Composites DiscussionReplies: 5Last Post: 09-16-2003, 09:56 PM
