Results 1 to 15 of 22
Thread: Merc Tilt Tube Rebuild
08-17-2017, 07:30 AM #15000 RPM
- Jun 2014
- South Carolina
- 161
- 28
- 13
- 59
- 54
Merc Steering Arm Rebuild
1998 Mercury 200 EFI OG750392
There is excessive play in the steering tube and I want to rebuild.
Can someone please provide a diagram for the assembly and/or part numbers for the bushings
My shop manual has nothing on this assembly..
thanksLast edited by NeedOne; 08-18-2017 at 10:07 AM. Reason: Updated Title
08-17-2017, 08:41 AM #2
Here this is easier. Just follow the link and it will have all parts for your motor.
http://www.mercruiserparts.com/v-150...-thru-0g760299
NeedOne thanked for this post
08-17-2017, 08:51 AM #35000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
Don't want to steal the thread but having the same issue. Rebuilt the rebushable parts but it's the center section that's got all the play. Any machine shops to drill and sleeve, or cut and weld. Or do I have enough of an excuse to throw it away and get a Giegertek clamp?
08-17-2017, 09:00 AM #45000 RPM
- Jun 2014
- South Carolina
- 161
- 28
- 13
- 59
- 54
08-17-2017, 12:09 PM #5
Chaz can get that squared away for you !! Give him a call
08-17-2017, 01:40 PM #65000 RPM
- Jun 2014
- South Carolina
- 161
- 28
- 13
- 59
- 54
Can someone confirm I have the general right idea on the procedure:
Crane to Engine lift point
Remove Hydraulic Steering Ram
Remove Bolts holding Brackets to engine with red arrows
Slide Engine away
Pull item 18 tube out from top
Replace 2x item 3
08-17-2017, 08:24 PM #7
since when has a this been a Tilt Tube ?
I make that the STEERING ARM not tilt tube.
08-18-2017, 05:59 AM #8
That is the steering arm you are referring to.
08-18-2017, 07:34 AM #9
08-18-2017, 08:10 AM #105000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
08-18-2017, 10:11 AM #115000 RPM
- Jun 2014
- South Carolina
- 161
- 28
- 13
- 59
- 54
vnemous liked this post
08-18-2017, 10:41 AM #125000 RPM
- Mar 2012
- Lake Hopatcong, NJ
- 218
- 31
08-18-2017, 12:25 PM #13
08-18-2017, 02:19 PM #145000 RPM
- Jun 2014
- South Carolina
- 161
- 28
- 13
- 59
- 54
08-18-2017, 02:59 PM #15
If it was fresh water and you got a cherry picker still not a big deal. 10 nuts and off with its head, powerhead that is
Merc tilt tube
By peedeerooster in forum Technical DiscussionReplies: 4Last Post: 05-09-2007, 10:43 AM
