Results 1 to 9 of 9
Thread: Need waxed, black gel coat
08-16-2017, 04:15 PM #1Supporting Vendor
- Jun 2008
- Maryville, Tennessee
- 1,019
- 28
- 28
- 49
- 258
Looking for source for a quart of waxed, black gel for interior of Allison. I have looked at West, and several other websites and can't seem to get interior or waxed gel to show up. Thanks in advance for any help.
Dave Hensley
1986 XR2002 /12" Mariner and string steering
18' Pugh Hydro
1992 XTB-21/225 ProMax
The barn is emptying out!!!
08-16-2017, 05:11 PM #2Member
- Feb 2017
- Florida
- 43
- 14
- 18
- 7
Try Fiberglass Coatings( fgci) . You can add sanding aid to unwaxed,same resoults.
LongShot thanked for this post
08-16-2017, 10:32 PM #3Supporting Vendor
- Jun 2008
- 1,019
- 28
- 28
- 49
- 258
Found it. Didn't see any specs on amount of additive per given quantity of gelcoat. I appreciate the reply. They have brushable which is how the finish appears to have been applied in the areas of the boat already done. I am touching up where I have bonded in aluminum mounts for seat, tank, pumps and throttle.
Dave Hensley
18' Pugh Hydro
08-17-2017, 02:35 AM #4
The product you are looking for is commonly known as flowcoat.
08-17-2017, 07:24 AM #5Supporting Vendor
- Jun 2008
- 1,019
- 28
- 28
- 49
- 258
FGCI actually has it listed as Sanding Aid. It is a 10% solution of wax. They just don't specify mixing ratios. I will look up flowcoat. They list a waxed gelcoat but only in a light blue color. The repair guys at Allison referred to it simply as interior gel and that it came with the waxed additive.
PS: I zoomed in on the picture of the container of Sanding Aid on the FGCI website and I can barely make out 1 oz. per quart. That was what I was needing. On another note I need to web the black with white spatter. I have heard some folks use paint with webbing solution. Some use paint at low pressure. I was talking to another very good restoration guy here and he used gelcoat to do his webbing. Comments?Last edited by LongShot; 08-17-2017 at 07:29 AM.
Dave Hensley
18' Pugh Hydro
08-17-2017, 08:15 AM #6Member
- Feb 2017
- Florida
- 43
- 14
- 18
- 7
fgci has a great tech support for their products. You want the finish coat to cure and not remain tacky so the sanding aid does that . You can web over the black with white gel,use webbing solution and the sanding aid if the white doesn't have wax. Spray the white ,low pressure or whatever the pattern is your trying to match. You would want to do the white before the black cures for good bond.Might take some practice,good luck, don't forget the mekp catalyst.
08-26-2017, 04:50 AM #7
I am not familiar with those proprietary names. But when it comes to industry terminology, Interior Gel will be another name for Flowcoat. You can buy Flowcoat. It is usually formulated for brushing. The additive for making gelcoat into flowcoat is "Wax in Styrene". Addition rate is usually 5%. The added styrene will reduce the thixotropic properties, so it won't brush or roll on as thick. I haven't mentioned any of the "special proprietary additives"
patchaid, sanding aid or bandaid because I don't use them or know any other industry people who do. Actually I do use bandaids
08-26-2017, 07:16 AM #8
Why all the fuse and bother and lots of questions just make you own black gel coat !Its only natural gel and add black pigment and a wax solution and if you use brushing natural gel is already thick enough add a little more pigment for interior use so will cover better !!simple !!!
For interior I always use a short hair mohair roller is quick easy coats a rough surface more evenly and no marks !!Last edited by tunnels; 08-26-2017 at 07:35 PM.
B.loco60 liked this post
08-26-2017, 03:00 PM #9Member
- Feb 2017
- Florida
- 43
- 14
- 18
- 7
I agree, this should have been done already.
base coat clear coat WITH PEARL chameleon added
By roadkill636 in forum Appearance ModsReplies: 7Last Post: 12-23-2015, 04:41 PM -
Just waxed the Allison
By whipper in forum Detailing and CareReplies: 6Last Post: 11-01-2015, 08:30 AM -
preping waxed resin
By kytekeith in forum Fiberglass and Composites DiscussionReplies: 2Last Post: 05-12-2012, 02:39 PM -
Real base coat / clear coat in a spray can results.
By Mr. Demeanor in forum General Boating DiscussionReplies: 4Last Post: 04-16-2012, 02:43 PM -
Waxed the boat today (not that I needed to!) - Pics inside!
By Scream And Fly in forum General Boating DiscussionReplies: 17Last Post: 12-27-2003, 10:26 PM
