Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 59 of 59
  1. #46
    Jun 2004
    port st. lucie, fl
    I was just thinking if there was something out there with a smaller bore and same bolt pattern it would be worth a try (provided the compact bowls and parts from the other set fit). I've talked to a couple of people who have run t2x and t2's, and a common complaint is poor idle, low speed throttle response and extremely poor mileage, which can be a symptom of overcarburetion. It could be other things also, but the port heights between a 115 adi and t2x only appears to be around .010 difference.
  2. #47
    Don't think they were thinking economy when , but a lean idle setting with enough timing and just enough rpm probably all you can do. Adequate fuel pressure also.
  3. Likes mrcrsr liked this post
  4. #48
    Jul 2005
    Regina SK. Canada
    "The only thing that worked was a TIIX front half with the 6 individual V reed cages and I ran 6 stock 1500XS carbs. Was like a different motor".I copied this from a post years ago ,someone who was very successful in SJ , I'm not sure who , but I think you're on the right track down sizing the carb size to get better responce on the low end and less fuel usage .If you can find a Tillotsen carb with similar dimensions but smaller throats I think it would be much more responsive . The last part of the throttle with the TC3A3 carbs makes very little difference .
  5. Likes FMP, mrcrsr, joyrider liked this post
  6. #49
    What size carbs are 1500XS? And what jets? Ex opens 3* sooner at 94* on the T2X, that adds as bit to fuel burn , weaker idle.
  7. #50
    Jun 2004
    port st. lucie, fl
    Xs engines use the same carbs as an adi in line but with different jetting. I'll check it out tomorrow. Btw I just degreed the t2x, and an adi 115. I'll post it up tomorrow
  8. #51
    That's intake
  9. #52
    Jul 2005
    Regina SK. Canada
    Then XS carbs have 0.082 jets ,the problem with these carbs is the mounting flang on the XS is diangle while the T2X is straight across so to use these carbs you need to make an addapter plate. So if you can find a similar force tillotsen carb it would simplify things .
  10. Likes mrcrsr liked this post
  11. #53
    Jun 2004
    port st. lucie, fl
    That's intake
    Actually both intake and exhaust are different, port area also
  12. Likes Mark75H liked this post
  13. #54
    Degree wheel doesn't lie but I've read transfer are the same except BP1000 at 114.
  14. #55
    Jun 2004
    port st. lucie, fl
    When I get the other block back from the machinist I'll degree it also. I heard that there was running changes with these engines
  15. Likes Mark75H, FMP liked this post
  16. #56
    Jun 2004
    port st. lucie, fl
    Was at the outboard boneyard today, had a 150 force, here's the carb number if anyone is interested. Only had 1 tube in the Venturi. Click image for larger version.
ID:	385271Click image for larger version.
  17. #57
    Yes those are them, different number top to bottom but all TC. Man , that's a salty girl. Take the whole thing home. Should have two, might be off to the side and hidden. Look in the throat, one large stops and thin tube continues to top.
  18. #58
    Jun 2004
    port st. lucie, fl
    I didn't have anything with me to measure the carb bore size (unexpected trip for parts for another job) are they smaller than the the t2x carbs?
  19. #59
    Just measured to make sure , written is 1.625 , 41.3mm venturi , 1.75 , 44.5mm throttle bore. Carb opening is 1.875 , 47.6mm , bore is 45mm, venturi about 42mm.
    No.
  1. Ebay Rebuild Kits
    By Fisher77 in forum Technical Discussion
    Last Post: 05-10-2016, 07:34 AM
  2. WH-20 carb rebuild kits
    By Derrek Curtis in forum Technical Discussion
    Last Post: 02-02-2007, 09:35 AM
  3. OMC rebuild kits ?
    By Rmart30 in forum Technical Discussion
    Last Post: 01-29-2007, 02:49 PM
