Results 31 to 45 of 59
  1. #31
    That's good stuff, shhhhhh. Quick cover it.
  2. #32
    Jun 2004
    port st. lucie, fl
    Quote Originally Posted by 25ss View Post
    My buddy has an old repair shop
    I went to his shop and got all of his old chrysler carb stuff.
    Dont know if any of this would help
    If you have some numbers i can see what i have.
    Her is pics of the stuff.
    Dale
    I pretty much need needles and seats, and the gaskets. I'm unsure of part numbers though. When I was going to start rebuilding carbs I was going to order kits for a force from pro marine
  3. #33
    Nov 2007
    florida
    Feb 2003
    peoria il
    This what i have in needles & seats
    The seirra kits 18-7033 have needles seats and gasket i have 3.
    Dale
  5. #35
    The CHRYSLER bagged stuff, jets ???
  6. #36
    Discount is good
  7. #37
    Feb 2003
    peoria il
    Some jets .039 to .082
  8. #38
    Jun 2001
    don't run it at factory jet sizes on todays gas. run it richer or only on Low lead AV GAS
  9. Likes Capt.Insane-o, mrcrsr, joyrider liked this post
  10. #39
    Why not, good Shell 91 or even 94 Sunoco with alc. It doesn't have enough compression?
    Sorry, T2X ... that has the high domes?
  11. #40
    Jun 2004
    port st. lucie, fl
    I measured the carb bores today, I don't have the exact size in front of me but they are.100 larger than a 2.5 carb. Probably a little over carbureted.
  12. #41
    Just measured to make sure , written is 1.625 , 41.3mm venturi , 1.75 , 44.5mm throttle bore. Carb opening is 1.875 , 47.6mm , bore is 45mm, venturi about 42mm.
  13. #42
    Jun 2004
    port st. lucie, fl
    What are some of the bore sizes in the tillotsen carbs on the force engines?
  14. #43
    Chrysler TC or smaller WB found on triples and 105 some early 115, Force followed along with updated versions. Sizes stayed the same. Weather Merc TC or Chrysler TC or ..... same sizes.
  15. #44
    Jun 2004
    port st. lucie, fl
    These things seem huge for what the engine displacement is, that's why I was wondering if there was something with the same bolt pattern with a smaller bore
  16. #45
    TC from an F5, not smaller. Notice no chokes
    Why do you want less carb? WB has a smaller mount than the TC. Tillotson has other pumper carbs that are smaller but not sure about the bolt pattern.
  17. Thanks Mark75H thanked for this post
    Likes Mark75H, mrcrsr liked this post
  1. Ebay Rebuild Kits
    By Fisher77 in forum Technical Discussion
    Last Post: 05-10-2016, 07:34 AM
  2. WH-20 carb rebuild kits
    By Derrek Curtis in forum Technical Discussion
    Last Post: 02-02-2007, 09:35 AM
  3. OMC rebuild kits ?
    By Rmart30 in forum Technical Discussion
    Last Post: 01-29-2007, 02:49 PM
