Results 1 to 15 of 18
Thread: Initial set up for a Vulture
08-08-2017, 02:01 PM #1Member
- Sep 2015
- Rockford, IL
- 41
- 13
Been working on my Vulture since the river has been closed by me and getting closer to putting it back in the water. It has a 77' Johnson 200 hung on a 12" jackplate with the standard water pickup. 21 gal tank in the back with the battery. Looking for advice on what type of prop to start out with. I know this hull needs a lot of bow lift, but with the prop being buried in the water would a chopper work or is there a better option?
08-08-2017, 11:11 PM #2
I have a 10"jp 200 merc turning a 26" chopper, prop shaft even with the pad. I would recommend borrowing props if you can.
08-08-2017, 11:36 PM #3Screaming And Flying!
- Mar 2003
- Belvidere IL, FARM
- 7,736
- 102
- 115
- 1556
- 514
Jhuff83, I also live and boat in your area, hope to see you on the river if it ever opens back up again, still a ton of crap floating down...
God, Country, and Fast Boats
08-09-2017, 08:28 AM #4
Choppers are intended to be run surfaced, so raising your motor will help running a chopper. You can only go so far without a low water pick up.... If you do look for a chopper, a newer large ear will work better for you to lift the bow than the older I6 small ear choppers. imo..
Also worth noting is most through the hub exhaust propellers tend to give some stern lift. Might not be what your looking for though.
Try as many props as you can....
Recommend a temp and water pressure gauge as well, especially when raising your motor.James H. W2F a V-King... Want 2 Fly a V-King
08-09-2017, 03:14 PM #5Member
- Sep 2015
- Rockford, IL
- 41
- 13
08-09-2017, 03:17 PM #6Member
- Sep 2015
- Rockford, IL
- 41
- 13
08-09-2017, 05:37 PM #7
I ran several omc props on my V6 Mercs...15 spline small shaft. Might have to get creative on thrust washers, etc.
One of the best props I ran on one of my checkmates was an omc prop.James H. W2F a V-King... Want 2 Fly a V-King
08-09-2017, 09:18 PM #8Screaming And Flying!
- Mar 2003
- 7,736
- 102
- 115
- 1556
- 514
Usually Sports Core, I have the Red/Silver and Black Metal flake Gambler Super Sport with the Promax on the back, so you live on the river? wanting to get out this weekend or early next week, news said for now it's open for running from Riverside south, let me know if you want to try and run some.
08-10-2017, 08:59 AM #9Member
- Sep 2015
- Rockford, IL
- 41
- 13
08-10-2017, 09:04 AM #10Member
- Sep 2015
- Rockford, IL
- 41
- 13
OK, I've seen you out before. I just bought my house last year, its just north of Latham on the west side of the river. I had the apricot viper last year and ran around with a blue Vking and a blue Vector. I don't know what the hell they are doing this year, but the river has been about 3ft high all summer long. Not sure how soon I'll be back out, still have to rewire the boat, get new gauges and get my jackplate put on.
08-22-2017, 10:56 PM #11
imho the vulture 20 ft is just to long and the front seats are to far forward . Had a 79 year and a 175 omc v-6 20 inch and it was a bitch to get up on the pad with what prop I tried and even worse with a passenger in the front seat next to me.Put him in the back seat and it hit the pad fast but what a piece of crap boat period and im talking just an all around family boat whay a piece of crap its just too long and not set up right from when it was built new.
08-23-2017, 11:21 AM #12Member
- Sep 2015
- Rockford, IL
- 41
- 13
roadkill636 liked this post
08-23-2017, 11:27 AM #13
Omc props WILL fit onto a merc propshaft BUT you will not be able to use the Merc nut or the spline lock tab. Because when the omc prop is on there there are no splines sticking out to grab onto. Therefore you will need a 3/4" flat washer and a THIN locknut to go onto the shaft to hold the prop on. And you will need to check the thin locknut each time in use.
08-23-2017, 11:47 AM #14Member
- Sep 2015
- Rockford, IL
- 41
- 13
08-23-2017, 12:37 PM #15
Opps. I misread. I was thinking you had a mercury and wanted to run omc prop.
Well then. You would need to drill out the splines in the merc prop from the front side of the prop to where there is only about 1/2" of splines in the prop in order for a mercury prop to fit onto your Johnrude. Or get a Flo-Torq prop with a OMC hub kit and it will all bolt up good and correct. If you want bow lift look at the Raker props OMC makes.
One more thing. Rember that lower unit was only made in 76 and 77 and uses a diffrent water pump impeller
Dw 28 initial test results
By JPEROG in forum General Boating DiscussionReplies: 56Last Post: 05-10-2018, 09:17 AM -
initial timming ...im at about 4-5 BTDC
By bcrector in forum Technical DiscussionReplies: 2Last Post: 07-05-2010, 10:59 PM -
Hydrostream HST initial set up with 260 or 280 2.5 EFI - Right prop & setback?
By RikkiRocket in forum Props, Setup, and RiggingReplies: 6Last Post: 10-14-2008, 09:25 AM -
Initial timing OMC Crossflow
By Lockjaw in forum Technical DiscussionReplies: 2Last Post: 02-05-2006, 10:29 AM -
2.4 EFI BP Initial Timing
By Carter Powell in forum Technical DiscussionReplies: 3Last Post: 06-19-2003, 06:25 PM
