Results 16 to 30 of 96
08-07-2017, 06:08 PM #16
08-08-2017, 03:33 AM #17
If you have the wire why not measure the voltage side of the coil ?
08-09-2017, 06:48 PM #185000 RPM
- Nov 2008
- martinsburg, wv
- 398
update - its not the flywheel. Put it all back together, took it down to the river and tested it on the trailer. It ran strong for a few seconds, then dropped the cylinder again and then sputtered a bit at idle - removed the plug wire off top port cylinder and no change. Removed the spare head, and there was a drop of water in the head and it too was cleaned off after about 8 - 10 minutes of runing. Im thinking maybe the new gasket i got was bad. It ran strong until water circulated and breached the gasket, then as water entered the cylinder, it stopped firing and began cleaning itself out.
https://imgur.com/gallery/NS4Ui
08-09-2017, 07:26 PM #19
Post # 9 maybe?
08-09-2017, 08:08 PM #205000 RPM
- Nov 2008
- martinsburg, wv
- 398
08-09-2017, 08:20 PM #21
08-09-2017, 08:31 PM #22
Also, take a close look at the inner plate (49) for holes; the space between the inner and outer plates (51) is a water cavity also.
Attachment 383300"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
08-09-2017, 08:57 PM #235000 RPM
- Nov 2008
- martinsburg, wv
- 398
will give it a shot after I replace the head gasket again. If that doesnt solve the problem, im looking at just throwing my spare block on and going with it. Upon closer inspection, I can see where water was leaking from the gasket, and one of the bolts was stripped, but being held in by corrosion - directly across from the plug hole on the problem cylinder. i drilled and tapped to 3/8", so i will give this a shot first.
08-09-2017, 10:35 PM #245000 RPM
- Jun 2009
- central minnesota
- 770
- 30
- 24
post#9
08-10-2017, 06:21 AM #255000 RPM
- Nov 2008
- martinsburg, wv
- 398
If it turns out to be #9, what is the best repair?
08-10-2017, 04:03 PM #26
Make sure the surfaces are level and new gaskets.
08-10-2017, 05:37 PM #275000 RPM
- Nov 2008
- martinsburg, wv
- 398
Alright pulled the exhaust covers off, but unable to tell if the gaskets were bad, as i had to pry it off. The top cylinder seems cleaner. There is DEFINITELY water entering that top cylinder from somewhere. Any other places it can come in? I ordered new exhaust gaskets.
https://imgur.com/gallery/qSMHo
08-10-2017, 11:54 PM #285000 RPM
- Jun 2009
- central minnesota
- 770
- 30
- 24
got sum cleanin and tappin to do.little hint--press 1/4x20 nut over square end of tap and use a socket on end of tap..-th
08-11-2017, 04:03 PM #29
How does the inner exhaust plate look? Any holes or cracks in the vicinity of the wet cylinder?
08-12-2017, 08:30 PM #305000 RPM
- Nov 2008
- martinsburg, wv
- 398
Question for experienced merc 280 owners
By Hot Shot Merc in forum Technical DiscussionReplies: 30Last Post: 01-05-2009, 04:57 PM -
Looking For Experienced Mechanic
By Just In Time in forum Employment ListingsReplies: 8Last Post: 09-22-2008, 12:20 PM -
Anyone here experienced a spirit of any sort....?
By Boz in forum The Scream And Fly LoungeReplies: 63Last Post: 04-27-2007, 06:29 PM -
Bridgeport Question For The Experienced
By BIG B in forum Technical DiscussionReplies: 22Last Post: 10-15-2003, 10:17 PM
