Results 61 to 75 of 139
08-12-2017, 07:43 AM #61
Thanks for looking Lynn, I appreciate it. I'm over at the machinist now to get the one block checked out, I'm not going to bore every cylinder if I don't have to
08-16-2017, 08:56 AM #62
I just bought a crank, rods and pistons off eBay that have the correct pistons. They are 3 ring so I'll just run the upper 2 rings, if I can't buy a new set of pistons. I still need 2 .015 pistons though
08-16-2017, 01:04 PM #63
I'll check at the marina in town. He has all kinds of nos stuff.
08-16-2017, 07:22 PM #64
Thanks Lynn!
08-16-2017, 09:02 PM #65The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
08-17-2017, 03:33 AM #66Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
What pistons do the guys run the 4 cyl kneelers? Must be something new
08-17-2017, 05:42 AM #67
08-17-2017, 09:07 AM #68
mrcrsr liked this post
08-17-2017, 03:44 PM #69
Twister cranks had a habit of cracking and breaking off just under the flywheel, did a couple way back when. Make sure you get it crack tested
Peter Thomas
Mark75H thanked for this post
08-19-2017, 02:24 PM #70action mobile marine, 772 528 0754, dealers for aces fuel products,wolf efi, pro marine,latham and gaffrig/livorsi. we build gearcases and modify them(3 litre) to ratchet, and powerheads as well. 21 skater/3 litre wolf efi 113 mph the engine build http://www.screamandfly.com/showthre...-3-litre-build
Mark75H liked this post
08-23-2017, 11:58 PM #71
On the block with the stock crank you should use the inner cover and outer covers for the exhaust from your ADI block and with the stock midsection, you will have a tuned exhaust system .Also you will have to use the reed blocks to replace the bearing blocks on the the 3 positions they occupied in the ADI block unless you can get Dick Austin to make you some single roller bearings like he made for his I6 Looper . On the T2X crank block on a stock mid the exhaust tuning will be way out , on the T2 the top 3 cylinders dumped out the bottom of the block into a large open midsection while the bottom 3 cylinders dumped into a 10'' long passage inside the mid . the passage was about 2x2 inches inside . If you take the stock tuner out and fabricate a passage for the bottom 3 cylinders 8-10 inches long you may be able to get the exhaust tuning back, on this engine the exhaust iuning is what makes it special . I found a new oversize non power ported piston on ebay part # 776-8900A2 used in later 90 hp engines. Ebay # 112495872708 , $45 .Keep us posted on your progress !
08-24-2017, 06:53 PM #72
Thanks so much, just purchased it. I'm going to build the t2x as the first engine, and going to use adi ignition on it. When I go to start on the project I'll start posting on it. Got another piece of the puzzle today, the 15" midsection
08-28-2017, 05:29 PM #73
I still need to find a .015 oversize piston, if anyone has one
08-29-2017, 12:40 AM #74
Take a look at ebay # 361445044838 part # 745-7673A2 $85 or same part# at marineengine.com $82
08-29-2017, 06:11 AM #75action mobile marine, 772 528 0754, dealers for aces fuel products,wolf efi, pro marine,latham and gaffrig/livorsi. we build gearcases and modify them(3 litre) to ratchet, and powerheads as well. 21 skater/3 litre wolf efi 113 mph the engine build http://www.screamandfly.com/showthre...-3-litre-build
Look at what I just picked up !
By outlaw 10.5 in forum General Boating DiscussionReplies: 20Last Post: 06-28-2016, 06:52 PM -
picked up a new toy!!!
By gettinwet in forum General Boating DiscussionReplies: 4Last Post: 08-18-2009, 05:20 PM -
Picked up my 92 Merc 245
By 91nitro in forum General Boating DiscussionReplies: 3Last Post: 06-05-2008, 09:36 AM -
Picked up my new car Sat.
By Ziemer in forum The Scream And Fly LoungeReplies: 9Last Post: 08-30-2005, 05:56 PM -
Picked up 700 RPM's today !
By BOUDREAUX in forum Technical DiscussionReplies: 2Last Post: 12-02-2003, 09:57 PM
