Results 1 to 3 of 3
Thread: 2005/6 Opti 135
    2005/6 Opti 135
    Will occasionally fall on its face and stall or need to throttle back to recover. No start or other running issues, will wot no problem, no water in fuel. Low hrs less than 200. Ideas?
    Ft. Lauderdale, Fl
    Fuel restriction, crap in high pressure pump fine filter (bottom of high pressure pump), stuck or plugged anti-siphon valve, collapsing / disintegrating /pinched fuel hoses, bad low pressure pump, bad high pressure pump, loose electrical connections..... failing pressure regulator diaphragm............ any of the above
    Get a fuel pressure tester and see it your'e losing pressure. Should be at 90 PSI all the time.
    I figured crap but , will check thanks
  1. Oil pump om 2005 225 opti
    By XstreamVking in forum Technical Discussion
    Last Post: 02-13-2013, 11:12 AM
  2. Proper Torque for Plugs on a 2005 Opti
    By eastfisher in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 07-03-2010, 07:12 PM
  3. 2005 Mercury Opti-Max 200 question
    By cocacola in forum Technical Discussion
    Last Post: 11-29-2007, 11:06 AM
  4. 2005 Opti 225
    By CMC in forum Technical Discussion
    Last Post: 01-27-2005, 10:33 AM
