Results 1 to 1 of 1
Thread: Avance 22' Prop Question
08-02-2017, 09:19 AM #1Junior Member
- Jul 2017
- VA
Hi all, I have an "04 Avance 22' with a 250 Mercury EFI that I am going to replace the lower unit on. The old lower was a torque master with the 1" shaft and I am replacing it with a torque master with the fat shaft so I am either going to have to rehub the Mirage prop I have or just get a whole new setup (which is the way I am leaning). I am running a 20" lower with an Armstrong bracket, I think 22", and trim tabs at the rear. Right now the 23 Mirage, not M+, gets me out of the hole with no problems however my top end at 5700 RPM is only about 53-54 MPH. The only mods to the prop is that I ported it. I do get some ventilating during a hard turn or when I am at the coast going over a wave.
I know there are a few folks that were on here that had an Avance 22 but, so far I can nail down what prop they were running. I think one was running a 25" and went to a 27" on a Yamaha and I have seen another site someone running mid 60's with a Merc and 21" prop but couldn't tell which one. I usually run with a Yeti 110, 100 lbs, in front of the console with 2 people, 450 LBS, fishing gear, 150 LBS, and a 27 gal livewell between the front seats, 250 LBS and 3 batteries in the console. If there is any other information I should be providing, please let me know.
Any help with prop selection to get me started would be greatly appreciated.
Avance 33 Cabriolet
By Avance33 in forum Hulls larger than 20'Replies: 10Last Post: 04-18-2016, 01:50 PM -
Avance 33
By Avance33 in forum General Boating DiscussionReplies: 30Last Post: 07-22-2013, 10:41 AM -
Avance Boats???
By skatermike24 in forum General Boating DiscussionReplies: 3Last Post: 11-30-2009, 09:14 PM -
22' Avance prop HELP...
By ivan2214 in forum Props, Setup, and RiggingReplies: 2Last Post: 10-28-2009, 10:25 PM
