Results 1 to 15 of 19
Thread: Reading plugs. Plug chop
08-02-2017, 06:28 AM #1
So i installed some new pluggs and drove a few minutes then did a wot chop at around 5500 rpm and here are the plugs. They look too white to me. These are new NGK pluggs and 50/1 synthetic blend oil on a steel bore 2.4 that has been modded. With square ported pistons and 1.52 exhaust and 1" intake spacer and wh20 carbs. Now here is the crazy part. Im running 90 and 92 main jets. What ya think?
08-02-2017, 07:39 AM #2
wont be able to read surface gap you will need to install gap plug i think b9hs or 8
roadkill636 thanked for this post
08-02-2017, 08:10 AM #3Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
why? a few min. and you see the dark pattern forming.
08-02-2017, 01:40 PM #4Junior Member
- Feb 2017
- Texas
Because you don't have a strap to see the burn line. Both ignition timing and AFR will effect where the burn line ends up. It tells you if the combustion event is pushing on the piston at the right time. Lean AFR burns faster than rich AFR.
08-02-2017, 02:38 PM #5
Iv never done a plug chop before. So i didnt know how long to run new plugs before doing a chop. Figured the newer the better. Cleaner.
08-04-2017, 07:49 PM #6
Read piston for mixture and plug strap for timing. Jay Smith posted a real good description on correct piston crown reading. Do a search.
Popey
roadkill636 thanked for this postFMP liked this post
08-06-2017, 05:20 PM #7
I have a set of B9HS plugs comming for another chop test. How long should i run it the chop it?..
Also just from these surface plugs can anything at all be read? Can i go ahaead and install the next size smaller jets?
08-14-2017, 11:00 PM #8
Got the set of b9hs in it today. Heres what they look like with a 4000-4500 rpm chop..
What ya think?
08-17-2017, 01:10 AM #9
Put a couple of hours on those plugs just cruising a round so you get a little color on them before you do the plug chop.
08-17-2017, 05:23 AM #10James H. W2F a V-King... Want 2 Fly a V-King
08-17-2017, 05:45 AM #11Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
If it's not eating fuel like you own a gas station, it's gonna be lean. Only motor I ever cooked a piston on, just before it went, I was saying how good it was on fuel consumption. And like popey sez, look at the piston tops......
08-17-2017, 07:04 AM #12
This thing is eatting fuel... i can go thru 25 gallons just after work running arround for a few hours
08-17-2017, 07:07 AM #13
In a perfect world you would put in a new set of plugs , start it up in gear run it wide open for 10- 15 seconds put it in neutral and click it off put the plugs in a rack and look at them with a magnifying light .
The dark ring around the porcelain at the base is the fuel ring . The color at the top is impurities like oil or the additives in the fuel .
The center electrode is the timing mark .
The ground strap show's the overall condition of the combustion cycle .
The long version of the above is here :
http://www.strappe.com/plugs.html
08-17-2017, 09:28 AM #14Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
08-17-2017, 04:08 PM #15James H. W2F a V-King... Want 2 Fly a V-King
reading plugs
By texasvector in forum Technical DiscussionReplies: 8Last Post: 12-13-2013, 09:49 AM -
Reading your plugs!?
By MidnightCarving in forum Technical DiscussionReplies: 2Last Post: 04-30-2011, 08:31 PM -
Spark Plug question/ Reading Plugs
By stratos976 in forum Technical DiscussionReplies: 7Last Post: 11-17-2010, 10:55 PM -
Reading plugs
By supergenius74 in forum Technical DiscussionReplies: 20Last Post: 05-31-2004, 07:21 PM -
need help reading plugs
By Tom in forum Technical DiscussionReplies: 13Last Post: 04-06-2002, 08:24 AM
