Results 1 to 15 of 19
Thread: 225 PM starter motor
07-31-2017, 07:21 PM #1Team Member
- Lake Coochiching, Ontario
- 7,766
- 276
- 487
- 1590
- 6 Post(s)
My starter motor spins, but the splines do not rise up to engage the flywheel. I tried charging for a couple of hours, no change.
Then this weekend I hooked up a 50A charger for 30 minutes and with 50A still on, no change.
So I think it's the starter. I bought a new one from Amazon. Any tricks to the installation I should know?
thanks
07-31-2017, 07:33 PM #2
Euroski thanked for this post
07-31-2017, 08:22 PM #3Team Member
- 7,766
- 276
- 487
- 1590
- 6 Post(s)
The starter is probably junk as it was stupid cheep. But but if it gets me through next week...
I would have thought that the 50A charger would turn a starter with no charge time.
08-01-2017, 12:56 AM #4
The bendix is sticking. It's been sitting a while I bet? Take a flat head and carefully push it up and turn it and I bet it goes up and sticks up, then hit the starter and see if it spins over if that's the case spray some lube on it and work it back up and down till it's free.
Very common on old Merc starters that have been sitting along time
WillySteve liked this post
08-01-2017, 07:20 PM #5Team Member
- 7,766
- 276
- 487
- 1590
- 6 Post(s)
Only sitting a couple of weeks. I put a bit of oil on it Sunday am. I can try a flathead this weekend.
I also arranged to have have my current starter rebuilt in case my cheap on is too cheap.
08-01-2017, 08:08 PM #6WillySteve Hendricks
20XDC Bullet/Modified Merc 260
295TF Charger/ProMax 225x-Sold!
'83-20' Contender Pickle Fork/Merc 2.4 ModVP BridgePort EFI-Sold!
'85-18' Stratus STV/Merc Hi-Po 2.4 EFI-Sold!
Freedom 240 DLX Fisher Toon/Merc 115
10' Cougar Cub/Merc 25HP On The Bottle!
18" Home Made Tunnel/OS .021XM Outboard on 50% Nitro and Expansion Chamber
08-02-2017, 02:31 PM #7
08-02-2017, 02:39 PM #8
08-02-2017, 03:51 PM #9
Sure there is: Bendix drive
From Wikipedia, the free encyclopedia
Jump to: navigation, search
A Bendix drive is a type of engagement mechanism used in starter motors of internal combustion engines. The device allows the pinion gear of the starter motor to engage or disengage the flywheel of the engine automatically when the starter is powered or when the engine fires, respectively. It is named after its inventor, Vincent Hugo Bendix.2005 APR FORMULA 2 ROOKIE OF THE YEAR
90 5.0, WillySteve thanked for this post
08-02-2017, 08:57 PM #10
There are FEW people in this World that know anything at all about engines, who don't know what a Bendix is.......I just saw a post from one!
Either that or somebody's jus bein'a Sm*rt *ss!!!
Call it whatever you want but I'll Bet'cha a Franklin that you can go to ANY Merc or OMC parts counter and order a BENDIX and walk out with one!WillySteve Hendricks
08-03-2017, 08:33 AM #115000 RPM
- Dec 2002
- jonesville, La
- 716
- 11
- 83
I've got a 60$ amazon starter I've been running for 3yrs with no problem, had it on a 245 and now on my promax, 0 problems so far
08-04-2017, 07:18 PM #12Team Member
- 7,766
- 276
- 487
- 1590
- 6 Post(s)
Sunday when I get back to the lake: Charge battery again. Try screwdriver and lube. Then try my $80 (with rush delivery) starter.
thanks
08-05-2017, 09:42 AM #13
Ok show me on any outboard parts breakdown where it says part/ Bendix! Oh, by the way wikipedia is a encyclopedia made up by common people,may or may not be correct. Just saying
Bendix, is a drive system, consist of, Armature shaft w/ splines,spring, drive gear, and nut.Last edited by perfmarine1; 08-05-2017 at 09:56 AM.
08-05-2017, 10:17 AM #14
08-05-2017, 10:45 AM #15
A Muffler Bearing for a Cadillac Converter!
Capt.Insane-o liked this post
Mercury Tech: Starter motor testing. 2.4 - 200
By dwiggl in forum Technical DiscussionReplies: 4Last Post: 02-07-2011, 09:22 PM -
Mercury Tech: Starter motor issues: 2.4 200
By dwiggl in forum Technical DiscussionReplies: 4Last Post: 07-12-2010, 08:50 PM -
2.4 Starter Motor problems
By activator22 in forum Technical DiscussionReplies: 8Last Post: 11-05-2001, 12:18 AM
