Results 1 to 7 of 7
07-30-2017, 07:55 PM #1
88 Hydrostream Valero YT Chine walk
Hey guys,
I just bought a 88 Hydrostream Valero YT with a Mariner 200 hp carb motor. It goes into chine walk about 65 mph and I was thinking about getting a cleaver prop. My thinking is that a stern lifting prop might make it run a little flatter and be more stable. This is my first Hydrostream so I have very little experience driving one. Any help would be great.
07-31-2017, 10:13 AM #2
Alot of things an cause chine walk, soft motor mounts, worn or poorly adjusted steering, motor to low, over trimed just to name a few. Need to do some checking and post more info.
07-31-2017, 10:32 AM #3Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Like Dave said, and I will add, more seat time. Ultimately, you control chine wok with the steering.
07-31-2017, 11:15 AM #4
I had go to school. My boat was chinewalking because of the loose nut behind the wheel...ME!
If your boat is setup correctly then it's you, not the boat.
08-02-2017, 09:12 PM #5
I got a vking yt. Chine walks around 75-80. Gotra work the wheel and get pass it.
16ft superboat
14ft vixan
15ft viper
24ft sleekcraft
21ft sleekcraft modvp
18ft action hst drag
18ft accelerator drag
21ft redline
18ft vking yt
20ft Allison grandsport
20ft laser 420
18ft X-Stream Vking
24ft banana
08-04-2017, 07:27 PM #6Team Member
- Lake Coochiching, Ontario
- 7,766
- 276
- 487
- 1590
- 6 Post(s)
I had a Virage with almos the same bottom at the YT
http://hydrostream.org/Specific%20Models/HullDesign.htm
It ran fastest with the propshaft not far off level with the pad (never measured) with no chinewalking. It would chinewalk with the engine lower.
08-04-2017, 08:56 PM #7
Thanks for the info David. The link was very interesting. I don't have a nose cone on the lower unit but have one ordered from Bob's. Once installed I will be able to get the motor higher. I might also look into more set back (4" now) because the link said the YT's require a minimum of 6" of set back to run properly.
Valero Chine Walk
By MUDSHARK in forum Technical DiscussionReplies: 23Last Post: 03-23-2009, 08:43 PM -
chine walk
By macutty in forum Props, Setup, and RiggingReplies: 31Last Post: 12-06-2007, 12:12 PM -
chine walk (help)
By captain chris in forum Technical DiscussionReplies: 9Last Post: 06-27-2007, 11:16 PM -
Chine walk help
By Lockjaw in forum Props, Setup, and RiggingReplies: 15Last Post: 06-26-2006, 04:08 PM -
Handling the chine walk on a Hydrostream
By flyboy in forum Technical DiscussionReplies: 7Last Post: 07-19-2003, 10:36 AM
