Results 1 to 9 of 9
Thread: A4 vs A5 Small-eared Chopper
07-29-2017, 11:01 AM #1
What is the difference between the A4 and A5 designation of the Mercury Small-eared Choppers?
The one link I found on the history of the Mercury Chopper is no good.
07-29-2017, 11:09 AM #2
None that I'm aware of, could have been a minor change in the alloy.
07-29-2017, 11:15 AM #3
Got it.
The chopper I broke was an A4 and the one I just purchased is an A5. Both small-eared choppers.
07-31-2017, 07:24 PM #4Team Member
- Lake Coochiching, Ontario
- 7,768
- 276
- 487
- 1590
- 6 Post(s)
The A5 blades are a bit bigger and it made a big difference on my SS2000. Or maybe just two props are never the same. The A5 never settled down. I could run 80 plus, but the bow never stopped moving. The older one ran on a string.
CHICKENHAWK thanked for this post
07-31-2017, 08:52 PM #5
Did you try different running it at different depths to see if it would change anything?
08-01-2017, 07:25 PM #6Team Member
- 7,768
- 276
- 487
- 1590
- 6 Post(s)
Yes, there was no sweet spot for the A5 chopper. At the time with a coned small gearcase my SS2000 was prop sensitive. Correct it ran straight with minimal steering. Wrong and the bow was never still. Perhaps an extreme example. All I wanted to say was the A5 was a bit different and it mattered to me. Your results may vary.
08-01-2017, 09:02 PM #7
Thanks for the insight. Initially when I got the A4 it was me, not the boat or how the boat was setup. Once I 'learned' how to drive the boat the chine walking went away, the nose still moved around a bit but it wasn't anything crazy; after all I am trying to balance it on the pad with nobody in the left seat. Then I threw an ear and that was the end of that prop. Now I have an A5 on the way and I'm hoping it works for me.
08-02-2017, 05:17 AM #8
You'll be fine.
08-02-2017, 08:44 AM #9
Chopper Prop: 26p Small-eared Chopper
By CHICKENHAWK in forum Propellers WantedReplies: 3Last Post: 07-19-2017, 11:59 PM -
ISO small eared chopper 14x24
By speedman79 in forum Propellers WantedReplies: 11Last Post: 03-10-2017, 10:18 AM -
will a small eared chopper fit on a v4
By chargerk1d 2 in forum General Boating DiscussionReplies: 2Last Post: 04-23-2010, 08:35 PM
