Results 1 to 14 of 14
    Pekin, IL
    removing head dowels from block
    I had never tried this till today and had zero luck. Any tricks? Thanks
    Rock
    Team Junk
    TX......somewhere?
    a little heat.. a little "taping".. a very good pair of vice grips.. a lotta patience!
  3. Thanks rock thanked for this post
    Sep 2014
    Iowa
    Yep. Propane torch and vice grips. Try to spin it back and forth and then pull.
  5. Thanks rock thanked for this post
    SE MN
    Wrap some 120 sandpaper around the dowel before you grab on with the visegrips. It will help it grip.
  7. Thanks rock thanked for this post
    Likes Dave Strong liked this post
    Pekin, IL
    Thanks
    Team Junk
    Sep 2015
    wilmington,Il
    Goodson tools has a collet style dowel pin puller that works great. On the really stuck ones coat the dowl with a little lapping compound for better traction
  10. Thanks rock thanked for this post
  11. #7
    Pekin, IL
    Got the stubborn little bastards. Patience was an understatement and certainly not my strong suit. Appreciate all the suggestions.
    Rock
    Team Junk
  12. #8
    Folsom, Cal
    Map gas torch works best!enough heat and they come out fairly easy
    "Whacker Smacker" #561 IHBA M/E div1 2007& 2006 first looser champion
    2007 Sportsmen Driver of the Year
  13. #9
    Pekin, IL
    Map gas torch is what I used. One came out easy but the other three were hand to hand combat. Thanks again.
    Rock
    Team Junk
    My son bought a big block of bee's wax for like $6 at the swap meet . he cut it into strips and put them by the saws and vise .
    I think the problem is that it's easy to get the dowel pin too hot . I use the wax to cool it down and it also wick's itself in the hole providing lubrication for the pin . If it still wont go , I get it all really hot and put the hose from a nitrous tank aiming at the pin , shrinks and will just about fall out by itself ...
  15. Likes W2F a V-King, rock liked this post
  16. #11
    Sep 2008
    Mass
    Quote Originally Posted by THP View Post
    Snap on makes similar tools. On smaller parts that have dowels stuck in them i grab them with the spindle collet on my bridgeport mill.
    Ive always had success using a Brass rod and tap it in 4 positions and they have always come right out.
  18. #13
    Pekin, IL
    I like the idea of nitrous. I was thinking about maybe a piece of ice but figured it would melt so fast it would be a waste of time. I used almost all of above ideas except collets. They are like sleeves. Some release easily and some don't. This particular block had blown a head gasket and ran for a while so crank, rods, and sleeve were ruined. Got the sleeve in and was ready to bore when I noticed that during sleeving process another sleeve had turned. Finally got sleeves in proper locations and last night I got it decked. I about took a whippin on this one but looks like it's finally going to work. Thanks again for all the suggestions.
    Rock
    Team Junk
  19. #14
    Mar 2004
    Durham Ct
    Vise grips / slide hammer. Either weld a coupling nut to the side of pair of vise grips and thread your slide hammer into it or take the adjusting screw out and use a long threaded rod as the bar for the slide hammer.
  1. mid can dowels
    By mach1magnum in forum Technical Discussion
    Last Post: 11-16-2013, 11:21 AM
  2. Removing stuck power head (suggestions)
    By shadow1986 in forum Technical Discussion
    Last Post: 09-10-2013, 02:11 PM
  3. Mercury Tech: Removing Power Head
    By HighVelocity in forum Technical Discussion
    Last Post: 02-11-2011, 11:29 AM
  4. Removing valve seats in aluminum head?
    By Euroski in forum Technical Discussion
    Last Post: 06-30-2008, 08:20 PM
  5. Minor block damage from removing head, help!
    By Pete Keppler in forum Technical Discussion
    Last Post: 04-18-2005, 11:09 AM
