Results 1 to 3 of 3
    Mar 2017
    virginia
    2002 200 EFI smartcraft
    will be rigging a very nice completely rebuilt 2002 200 EFI on my hydrostream voyager today. will be using analogue gauges because the smartcraft gauges are so expensive. but i see a reasonably price smartcraft monitor that I would like to buy for getting better, detailed alarms and info. my question is can I run analogue and the smartcraft monitor together? yes, separate wiring systems, but does putting in a sc monitor affect the analogue abilities? all advice welcome
    Mar 2011
    Carrollton VA
    Yes, you can. They will not affect each other. Guess who.
    Go Time
    2003XS GS 225 Promax
    26 Regulator twin 250 EFI
    Feb 2005
    dont use the digital; trim. it reacts too slowly vs then analog.
    the tricky hook up is the GPS. the message required is nmea 2.0 but with a 2 digit deciamal resulation. eg 33.44 .
  1. Help with hooking up Smartcraft Monitor 2002 300x
    By at100plus in forum Props, Setup, and Rigging
    Last Post: 08-12-2017, 12:35 PM
  2. 2002 200xs Optimax and Smartcraft
    By Aussie_Pilot89 in forum Electronics, Audio Systems, and Wiring
    Last Post: 02-17-2017, 08:18 AM
  3. Baffled - 2002 200 EFI Smartcraft Motorola ECU overheat at 5000 RPM plus
    By crankbearing in forum Technical Discussion
    Last Post: 08-21-2013, 07:22 PM
Diamond Marine
