Results 1 to 15 of 34
Thread: Cylinder rounding tool
07-18-2017, 08:03 PM #1
What does the cylinder rounding tool look like? Are they home made shop pieces or are they made at a factory?
07-18-2017, 08:17 PM #2Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
Anybody could build one if they had a mill and lathe. Lot easier to call Michael Clemmons at Outback Outboards and buy one. They're not that much
Erik Kiser
07-18-2017, 08:23 PM #3Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
I cut a old piston in halve and use a hammer pry weadge and Wack it.....Heat don,t matter. but helps
07-18-2017, 08:54 PM #4If I don't ask any questions, I'll never learn anything.
07-20-2017, 05:43 AM #5Screaming And Flying!
- Sep 2001
- shreveport,la
- 5,706
- 118
- 85
- 773
You don't quite understand the concept. The part you posted will apply pressure evenly to the entire circumference. The idea is to straighten out of round bores. To do so you have to apply pressure where you want it, not the whole thing. The tool is available from Outback Outboards.
Erik Kiser
07-20-2017, 07:39 AM #6
Thanks, I'll give them a call.
07-20-2017, 09:11 AM #75000 RPM
- Apr 2002
- Eastover, NC
- 235
[QUOTE=patchesII;2972386]Anybody could build one if they had a mill and lathe. Lot easier to call Michael Clemmons at Outback Outboards and buy one. They're not that much[/QUOTE
Do you have a number for Mike? Thanks.
07-20-2017, 03:49 PM #8Supporting Vendor
- 11,838
- 163
- 11
- 795
I've built them for years .
First built by Jim Ruck then I copied them after Jim stopped making them I've sold many of them for straightening all 3.500" bored nickle or steel .
Jayb
832 597 3603Jay @ JSRE
SHADOW liked this post
07-20-2017, 04:09 PM #9
i watched jim ruck
do mine years ago
07-20-2017, 05:20 PM #105000 RPM
- Sep 2014
- Iowa
- 280
- 16
- 44
- 89
How out of round do these fix? Had a 2.0 for years that has had terrible leak down numbers even with new rings and suspect the bores are out of round.
07-20-2017, 05:42 PM #11
07-20-2017, 06:09 PM #125000 RPM
- Apr 2002
- Eastover, NC
- 235
07-20-2017, 07:08 PM #13
Anyone care to share their photos of this contraption.
07-20-2017, 07:22 PM #14
On the crossflow motors we make little wedges to push cylinder back straight, then drill 2 holes in the wedge to help keep it cool, works like a charm. Cyl are thin on them so all of them warp up top.
07-20-2017, 11:10 PM #15
Do cylinders mostly become out of round on the top third where there isn't any backing
Tool box fs/ft
By JHuff83 in forum Non-Marine ItemsReplies: 0Last Post: 10-27-2016, 10:53 AM -
Dual cylinder hydraulic vs single cylinder on a single engine application
By 1BadAction in forum Props, Setup, and RiggingReplies: 3Last Post: 07-11-2015, 03:42 PM -
Tool Name?!?!
By Stv Euro in forum Technical DiscussionReplies: 3Last Post: 04-08-2003, 10:40 PM
