Results 1 to 5 of 5
Thread: Hydraulic steering setup
07-15-2017, 08:36 AM #15000 RPM
- Dec 2011
- united states
- 494
- 7
- 7
- 25
I was wondering if you guys can help me with my steering setup. I currently have sea star front mount hydraulic steering with a 1.7 helm. I'm running it on a 21' Superboat with a 2.4/2.5 Merc. I am thinking about switching to side arm steering like Latham or Mayfair. I would like to know if the side arm changes the handling of the boat. Mainly when docking or at idle. Does it make the boat more nimble or do you lose some handling. How is it when running the boat? Is the steering easier to turn with the side arm vs. sea star? And also I've heard that you can run side arm steering with a sea star helm as long as it's not a sea star pro helm. Does that mean my 1.7 helm will work? And how do you guys make the extra reservoir tanks if the helm does t hold enough fluid? Thanks so much for any help!
Cory
07-15-2017, 10:15 AM #25000 RPM
- Nov 2001
- upstate newyork
- 441
I may be wrong on this, but I believe non of the sea star stuff is compatible with latham(if that's your plan). Not sure about the handling but I would guess the latham steering is more accurate than the sea star. I have sea star on my progression. A friend has the same boat with latham. My boat handles well but I think his might handle better. The latham stuff is a lot more expensive than sea star. Your also gonna have to modify the bottom pan on you engine cowl. Prepare to spend some dollars for that conversion. Good luck
01-21-2018, 12:44 PM #3Member
- Apr 2017
- key largo florida
- 41
- 10
Cory
Older thread but I have the same question.^^
01-22-2018, 08:00 AM #4Member
- Oct 2016
- Sweden
- 31
Even if you add a reservoir you will end up with a lot of turns lock to lock with a 1.7 pump and a side ram. I have an Imco and a 2.4 pump, ended up with about 5 turns lock to lock.
Correct, you cannot use a seastar pro helm with an unbalanced ram.Last edited by Hydro2.5; 01-22-2018 at 08:05 AM. Reason: Added content
01-22-2018, 08:15 AM #5Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
I remember a thread on here about the side steer, sea star helm and even the res under the dash mod. Might come up in a search? It has been posted....
Hydraulic steering setup on twins
By tony brimeyer in forum Technical DiscussionReplies: 18Last Post: 03-27-2012, 06:00 PM -
OMC 235 OB Hydraulic steering setup questions
By slawson2000 in forum Technical DiscussionReplies: 0Last Post: 07-13-2006, 11:00 PM -
Hydraulic steering setup for my STV
By STV_Keith in forum Technical DiscussionReplies: 1Last Post: 06-29-2005, 05:05 PM
