Results 1 to 4 of 4
Thread: 300 HPDI Mods
    May 2017
    Babylon new York
    300 HPDI Mods
    Just purchased a 22 Activator with a 300 HPDI Yam on it from the Doc. Some of you may have put more power & or reliability into keeping these engines alive and healthy. I'm all ears for your suggestions and experience with these engines. TIA for your replies.
    Forgot to add that I know about Hydro-Tech and did do a search on here about the HPDI.
    Oct 2009
    Gonzales, La
    I have a pair of 300 vmax hpdi's on a 23' eliminator. Both have hydrotec stage 2 kits, which includes the high compression heads, solid motor mounts, and shortened tuner. The heads raise compression from the stock 87 octane friendly 115 psi up to a more 300xs-ish 135 psi. You have to run 91 or better octane.
    I found that modifying the stock airbox can net a 2 mph gain. I did back to back testing and repeated this. Maybe we can work out a trade because one of my motors has a modified airbox and hydrotec reeds/cut reed cages. I'd like my motors to match. Let me know what you think.
    the thing I ran into was that with the 1.75 ratio and 6150 limiter, you have to run a pretty tall prop to get good speeds. However, apparently hydrotec can raise the limiter now with a reflash.
  3. Thanks FrankU thanked for this post
    Likes Instigator liked this post
    May 2017
    Babylon new York
    The engine has a velocity stack unit on it. But I may be interested in the Hydro-Tech carbon reeds and cut cages.
    longisland ny lindenhurst
    Strong engines. Im bumping the limiter this spring on mine. Mines a stage 3 with all the goods. Runs nice and cool. No issues. Great engines
    16ft superboat
    14ft vixan
    15ft viper
    24ft sleekcraft
    21ft sleekcraft modvp
    18ft action hst drag
    18ft accelerator drag
    21ft redline
    18ft vking yt 300 yamaha!
  6. Likes Instigator liked this post
  1. Yamaha HPDI ECU Mods
    By lance in forum Low-Emission Outboard Engines
    Last Post: 11-20-2017, 01:41 PM
  2. 03 HPDI 175 bad ecu ?
    By cali kid in forum Low-Emission Outboard Engines
    Last Post: 08-26-2015, 05:16 PM
  3. 250 vmax hpdi with mods
    By bayratpg in forum Outboard Engines
    Last Post: 11-20-2014, 12:32 PM
  4. 08 hpdi 250
    By rickriddle in forum Low-Emission Outboard Engines
    Last Post: 09-01-2013, 08:57 PM
  5. Yamaha Tech: Turn My 175 HPDI into a 200 HPDI
    By BroCo in forum Technical Discussion
    Last Post: 07-27-2009, 01:53 PM
