Results 1 to 5 of 5
    Apr 2015
    saskatchewan
    etec 225 lift pump
    has anyone every had issues with their lift pump cracking and leaking??? The pump still works and the motor runs fine, but this is an obvious problem. No kits or parts available to fix this issue, its new or nothin. kind of aggravating at $600. is their after market pieces or solutions that you guys have used or is new my only option????
    Apr 2015
    saskatchewan
    Well if anyone was curious, it IS new or nothing. Was odd how the plastic housing cracked out of nowhere on the discharge side, but its just my luck. One of my local dealers is gonna try to steal some parts from an old one but its not a for sure fix. so at best I will have a spare.
    lindsay on. canada
    J B Weld may be your friend
    Mar 2015
    bunnell FL/old town FL
    Penman over in misc parts is parting out a 250ho prob the same lift pump
    2003 mirage ski racer with e-tec power
    Apr 2015
    saskatchewan
    Quote Originally Posted by frank jackson View Post
    That was the first thing to cross my mind, but usually it doesn't like to play with gas In my experience.
  1. Mercury fuel pump lift power?
    By s10gto in forum Technical Discussion
    Last Post: 06-19-2015, 06:09 PM
  2. yamaha 4 stroke lift pump failure
    By sodibc in forum Technical Discussion
    Last Post: 07-20-2010, 04:47 PM
  3. Can a Holly Red be used as a lift pump for 260 efi??
    By twig in forum Technical Discussion
    Last Post: 08-09-2009, 04:31 PM
  4. Older CMC Power Lift pump swap
    By coffeeguy in forum Technical Discussion
    Last Post: 05-22-2009, 02:49 PM
  5. Holley Elec. Fuel Pump Lift
    By Hooty in forum Technical Discussion
    Last Post: 01-25-2004, 08:06 AM
