Results 16 to 30 of 32
Thread: 33 Donzi
07-19-2017, 04:36 PM #16Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Post #10
07-19-2017, 04:40 PM #17
If you are buying the core only with the intentions of making your own panels then you can use what ever resin system you find the cheapest ! so apart from the resin the choice of glass fabrics would be next !!
There is more than one core!! they come in any variations so check carefully the type and what it is !! (low density 1/2'' thick H-45 divinicell ) but there is no description as to what it really is !! get a sample to be sure its what you are wanting ! if it sheet foam make sure you get perforated ! has lot bleed holes to let the resin come up or down and lets the air out from underneath !!! How do you intend to stick the core to the glass ??
You would also need a nice shiny table top to mould on ! not forgetting gel coat to be sprayed on to lay your glass onto and get a nice finish . You can cut the core to the shape and size required and make each panel and have very little waste !
Now think about how you intend to make and all the work involved !the core is just a part of the whole thing ! ADD to that resin glass and gel coat, mould release wax ,and a ,shiny or patterned melamine board to mould the sheets on top of plus buckets ,rollers masking tape etc etc
To even come close to getting a quality jobthe gel coat would need to be spayed ,and the core would definitely need to be vacuum bagged onto the glass surface !
Suddenly are any of those premade panels really that expensive ?? remember there will have a manufactures guarantee of quality and consistency!.
Reminder the floor you would need a better core than H45 !! 3/4 x H65 would be the absolute minimum density ! H80 Is much better for walking surfaces !!, the glass layup is important, so top surface gel coat and 1708 then 3/4 core thickness core !! over that 1708 + a unidirectional running across the panel NOT length ways !!Last edited by tunnels; 07-19-2017 at 09:52 PM.
07-19-2017, 08:57 PM #18Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,645
- 606
- 923
- 1699
- 7152
- 3 Post(s)
07-19-2017, 09:47 PM #19
It doesn't cost a manufacturer $200 per panel to laminate them. I can laminate 8 panels in a day plus materials and with my lack of experience (doing it slow) it still would not cost $200 per panel to laminate. I'm sure the manufacturer all set up can do it for far less.
07-19-2017, 11:04 PM #20Supporting Member
- Apr 2003
- 6,645
- 606
- 923
- 1699
- 7152
- 3 Post(s)
You just want 8 panels (4X8) of high density foam with a layer of 1208 and peel ply on each side correct?
07-19-2017, 11:26 PM #21"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
07-20-2017, 12:49 AM #22Supporting Member
- Apr 2003
- 6,645
- 606
- 923
- 1699
- 7152
- 3 Post(s)
Okay,
I will have the guys put some numbers together for me tomorrow. I know that he has some inexpensive resin that could be used for what you are doing.
07-20-2017, 12:52 AM #23Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
07-20-2017, 01:23 AM #24
07-20-2017, 04:46 AM #25
A buddy of mine had the same problem with termites they didn't stop at bulk heads and paneling they ate out the stringers too
tunnels liked this post
07-20-2017, 09:59 AM #26Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
07-20-2017, 11:47 AM #275000 RPM
- Jan 2013
- GA
- 212
- 35
- 10
- 43
- 32
Again.. Carbon-core for around $180 laminated. Shipping was $120 to middle GA for 6 sheets.
08-28-2017, 09:09 AM #28
so what was the final choice of materials ?? what was the final outcome ??
08-28-2017, 03:45 PM #29
Job has been cancelled..... he had the boat tented and it slipped off the lift and sunk. The exterminator wanted the boat in the water so he let the boat down into the water and left it in the lift. Boat drifted back a little, tide went down, lift held the front of the boat up and the transom deep sixed.
08-28-2017, 06:49 PM #30Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
18' Donzi
By frederick55 in forum Ebay Listings and Other Internet ListingsReplies: 1Last Post: 07-18-2015, 07:42 AM -
What Donzi 16 is this???
By CraigFPG in forum General Boating DiscussionReplies: 11Last Post: 08-15-2014, 09:49 AM -
18 donzi
By challenger 77 in forum General Boating DiscussionReplies: 6Last Post: 04-10-2014, 08:03 PM -
Donzi
By Dr1532 in forum General Boating DiscussionReplies: 7Last Post: 10-15-2007, 12:50 PM
