Results 1 to 15 of 32
Thread: 33 Donzi
07-06-2017, 09:32 PM #1
33 Donzi
I'm in the process of rebuilding the cabin of a 33 Donzi closed bow.... The wood cabinets and walls became infested with termites and we had to strip everything out and now have just a bare hull inside. Wanting to put it back together without plywood and am looking for the most economical but permanent way. I see Coosa is about double the price of marine ply and that is a little high. Looking for something in 4'X8' sheets 1/2" thick that termites and water won't affect. The original walls were not tabbed into the top deck, in fact, they were about 3/4" under with the headliner floating above them. They provide no structural strength, but I do intend on tabbing the walls into the top deck when I put it back together. Doing the floor as well, floor is only about 2' wide and has a center stringer for support. Was thinking of using boatyard resin and 6' or 12" wide fiberglass tabbing to tab all the pieces together and coating the rest of the walls with resin. Everything will be covered with carpet or a foam backed fabric or vinyl.
Recommendations?"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
07-06-2017, 10:53 PM #2
good place to look at PLASCORE PANELING or MAKE YOU OWN !! NOT THAT DIFFICULT JUST CORE WITH GLASS EACH SIDE !!! COULD EVEN HAVE A GELCOATED SHINEY SURFACE ONE SIDE IF YOU MADE THE PANELS ON A SMOOTH SHINY SURFACE !! JUST THINK WOULD BE 100% COMPOSITE NO MORE WOOD !! COULD USE THE SAME STUFF FOR THE FLOOR WITH A THICKER CORE AND BETTER GLASS AS WELL
ALL AT A FRACTION OF THE WEIGHT OF WHAT WAS THERE BEFORE !!Last edited by tunnels; 07-06-2017 at 11:00 PM.
07-06-2017, 11:01 PM #3
07-06-2017, 11:03 PM #4
try shopping around for the materials and then the ready made panels .and see what sort of a deal you can get !
https://www.plascore.com/honeycomb/honeycomb-panels/ some reading matter !!go through the site and get to know what you dealing with !!
https://www.plascore.com/download/da..._Honeycomb.pdf
if WAS ME DOING THE JOB ID MAKE THE PANELS TO SIZE AND CUT DOWN DRAMATICLY ON WASTE oFF CUTS COULD BE JOINED TOGETHER TO MAKE PANELS AND THE GLASS COULD BE LIGHT DOUBLE BIAS WITH CSM BOTH SIDES JUST THE FLOOR WOULD NEED A HEAVYER BETTER GLASS !! no more termites !!Last edited by tunnels; 07-06-2017 at 11:27 PM.
07-06-2017, 11:12 PM #5
Just trying to find the right products to use but most economical, figured the guys here would know ballpark prices
07-07-2017, 01:50 AM #6
The plastic honeycomb core would do everything you need !
Thickness 1/2inch for wall panels and 3/4 inch for the floor panel !!
Glass csm 450 gram and 600 gram double bias 45/45 fabric that has a csm on one side !!!
Resin for interior construction polyester is perfectly ok
Measure how big are all the panels to get the square foot plus a little wastage !Last edited by tunnels; 07-07-2017 at 03:58 AM.
07-07-2017, 04:01 PM #75000 RPM
- Jan 2013
- GA
- 212
- 35
- 10
- 43
- 32
You might check prices and shipping from Carbon-core. I have used their pre-laminated panels and found them to be well made and finished. It appears to be the same as Plasti-core.
07-15-2017, 04:44 PM #8Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
07-15-2017, 06:19 PM #9
Having a tough time finding a local supplier who won't rape me on the price.
07-16-2017, 05:37 AM #10Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Have you ever bought from Merritt Supply. They used to be good suppliers for all kinds of stuff. Core board, core's. and at one time had pre finished glass panels from orca industries. If you want to make some glass panels yourself it's easy...Just use some flat melamine board, wax it, brush on some gel, couple lays of matt, set core, ( lo density 1/2'' thick H-45 divinnycell ) in the wet glass and cover with a couple more lays of matt. You can make the panels in the shape (even bowed) you need so you don't waste any materials. The melamine board gives a nice matte finish for interior panels.
07-19-2017, 08:39 AM #117000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
07-19-2017, 08:41 AM #127000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
How much they want?
07-19-2017, 08:50 AM #13Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,645
- 606
- 923
- 1699
- 7151
- 3 Post(s)
Composite one is around 60 a sheet if can find someone local that is set up with them. If not, give me a call and I can get it if you want to make a drive up.
07-19-2017, 03:52 PM #14
07-19-2017, 03:58 PM #15"One of the penalties for refusing to participate in politics is that you end up being governed by your inferiors". Plato .
18' Donzi
By frederick55 in forum Ebay Listings and Other Internet ListingsReplies: 1Last Post: 07-18-2015, 07:42 AM -
What Donzi 16 is this???
By CraigFPG in forum General Boating DiscussionReplies: 11Last Post: 08-15-2014, 09:49 AM -
18 donzi
By challenger 77 in forum General Boating DiscussionReplies: 6Last Post: 04-10-2014, 08:03 PM -
Donzi
By Dr1532 in forum General Boating DiscussionReplies: 7Last Post: 10-15-2007, 12:50 PM
