Results 1 to 8 of 8
    Apr 2010
    Texas
    Battery that cures the Mercury 300xs dragging starter woes (group 24 battery)
ID:	379603Deka 24M7 Marine Master... DONE! The 300xs requires 800cca or 1000mca. I replaced a new EverStart 24DC with this battery and am far more pleased with the start capacity; and even the reserve capacity to run audio, while still starting the motor with out crossing my fingers.
    Jun 2002
    Northern Utah
    I need a group 24 replacement. Saw this one at Sam's Club.
    Western Pennsylvania
    Just go to Batteries' Plus, Advance Auto, AutoZone and buy a AGM marine battery. I replaced my Sears Marine AGM which was 7 years old and not bad yet. Just a preventive thing. I purchased top-post AGM only because it had date code 9months old at Auto Zone and AZ reduced the price to $50 from $200 when I commented on the date code. AZ has the terminals to convert for marine use. Also only think there are a few battery producers in the USA... so it's same battery different labels. Other than maybe the special batteries.
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
    Quote Originally Posted by rtigert View Post
    I got one full season out of my Deka's with 300XS's. They won't spin the motor fast enough to build starting air pressure.
    Sure look good though. :-)
    May 2009
    Ormond Beach, Florida
    I'm using this Exide AGM battery and although it's only rated to 930mca it has no trouble firing off the 300XS. AGM batteries have a capability called pulse current, it's a brief burst of current that can add another 25% which may explain why it doesn't have any issues. If, over time, my assumption is proven incorrect I'll need to find something else. Batteries are a consumable item so it will get replaced at some point.
    Mark
    8 Post(s)
    I thought 24v cured it?
    Toronto, Canada
    Just attach a Lithium jump starter right away and you'll never have a problem starting.
    May 2009
    Quote Originally Posted by JohnG View Post
    I've got one of those onboard just in case
    Mark
  1. 300 XS Battery woes
    By 90mph in forum Technical Discussion
    Last Post: 01-15-2008, 08:57 AM
