Results 1 to 4 of 4
07-06-2017, 06:26 AM #1Junior Member
- Jun 2016
- Holland
- 18
Difference between 28 et 4 blade en pro max 28 4 blade....!!!!!!!!!!!
hello, i am Thierry lefevre from holland, i have at the moment a ET 4 blade prop...but i wanne chance my prop to a mercury pro max prob............i try to get information everywhere even bij mercury belgium if if i now turn a 30P et prop , the mercury pro max 30 p wil be also good for my...wil my engine make the same rpm with it...? ore is ther a big difference.....it is onbeliveble that nobody of de dealer in begium knows the anser on that......HOW can i buy that prop than...? .......PLEASE HELP MY..!!!!!!
07-16-2017, 01:28 PM #26000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
thierry,all I can say is that the promax is very stiff prop,so if you need 30p it will be 30p,i think promax gives more bow lift than et4, I have an et4 that lifts and flys mod vp hull,but runs very flat on my allison xb03.
Thierry Lefevre liked this post
07-16-2017, 01:31 PM #3
The ET is an over the hub design and the Pro Max is a thru hub design.
08-17-2017, 09:40 AM #4Member
- Nov 2015
- Ky
- 77
If u want a promax. I have a new 28 promax that I would consider trading to the 28 pro et. The 4 blade et.
Lost a blade on my 3 blade Mercury Lightning ET and ......
By Stålproppen in forum Technical DiscussionReplies: 24Last Post: 07-20-2016, 06:48 PM -
Drag 4 32p, Hoss 4 blade 28p, mercury et 3 blade 32p
By Mercaholic86 in forum PropellersReplies: 22Last Post: 05-02-2016, 02:41 PM -
Ron hill signature eagle et 4 blade or 5 blade
By frontline in forum General Boating DiscussionReplies: 10Last Post: 08-27-2014, 06:42 PM -
comparable 4 blade ss prop to a BRP rogue 4 blade?
By zwalls in forum Props, Setup, and RiggingReplies: 0Last Post: 09-03-2011, 09:49 AM -
3 blade laser II prop or 4 blade offshore?
By Air Dog in forum Props, Setup, and RiggingReplies: 7Last Post: 04-05-2006, 11:56 AM
