Results 1 to 10 of 10
    May 2008
    Arkansas
    Gambler Outlaw and 200xs?
    I know the Gambler guys like the 3 liter opti motors on the bigger Gamblers. However, they weigh 508+ and I have a Gambler Outlaw, year 2000 model rated for a 200. Why wouldn't a 200xs work well on my boat? Its a single console and at least 200 lbs lighter than the 2000, 2100, or 2200 models. Think it weighs about 1,300lbs. I have a 200 opti 3 liter on it now and it looks huge! My thought is to save 80 lbs on motor weight, go to a two battery setup and lighten the equipment load and see if this 19' 4" Outlaw can perform and handle better with a 200xs. Now I just gotta find one with a 20 in mid section. Anyone else try this motor on an Outlaw or 19'3" intimidator? Thanks, Sam
    Feb 2013
    mt holly,nc
    my opinion,for what its worth(probabally0):i had a outlaw a while back,pretty sure in was a mid 90's?anyway,it had a 200 johnny(looper) on it and 3 50lb sand bags in the front compartment."well thats stupid,weight costs speed"i said to myself as i quickly liberated the sand bags from the boat.1 hr later it became VERY clear why they were there!the boat had an incredible hole-shot and climbed up on the pad nice,then,i crossed a 1ft boat wake @60mph and found myself looking down at the boat that made it!seemed the boat would jump air-born on any size wake at all but slow speed.i sold the boat 3 weeks later as i had only bought it for the motor.i probably would have kept it but the hull was in real rough shape.
    May 2008
    Arkansas
    Quote Originally Posted by skeeter91 View Post
    Gambler re-designed the Outlaw in the late 90's, made it a much better boat with stronger transom, stronger stringers and slightly longer hull as they went to 19' 4" and upped the HP rating to 200 from 150. I had this boat to upper70's with 3.3 Liter Rude turning a 27 BASS Renegade. Just want an 80 mph setup keeping this hull.
  4. Thanks skeeter91 thanked for this post
    Mar 2010
    houston, tx
    I think that should be a very good combo, guy I tourney fish with has one with a 200xri on it that runs pretty good he's had it for a long long time.
    Holeshots good and drives good.
    Feb 2013
    mt holly,nc
    i always wondered if the later ones handled a little better.A good friend of mine,has a 92' 20 footer and said it rode/handled completely (better)different.i have a 91' 20 footer i hope to complete soon,looking forward to getting seat time.A 3.3 with the right set-up/prop combo should get you in the 80's no problem.general consensus is these hulls like stern lift,God knows,they dont need any at the bow!
    Dec 2011
    Ottawa
    A 250xb or 300 pm are in the 445lb. Range not much heavier than a 2.5 opti.... just sayin' you dont need an opti to have awesome 3l power, most gamblers that i ever saw ran the 250xb
    Feb 2005
    seattle
    i have a 200xs on a voyager set up as a bass boat. its a very good choise for a liter boat ;ike the one you have. it was tested on a allison grand sport and saw over 90. plus it sips gas. i have seen 74 on my smartcraft guages using gps.
    just keep looking the show up in the ob section. i found one last yr that was 2 digits newer then my main motor.
  9. #8
    Aug 2015
    Southeast
    I have a 200XS 20 inch mid with about 95 hours on it. I'm running it on a Seebold Ski Eagle mod vp hull. It does 80 with 2 people. Hull and motor weighs a bit under 1600 pounds. I'm looking around for a good 225 promax to get a little extra power. I've only run it a few times since putting the combo together. Everyone says how it sips gas, I haven't really experienced that but I usually run it upper rpm. Maybe it sips at 4,000 rpm. I don't have a smartcraft gauge so not really sure what burn rate I'm getting, but I don't have any problem burning 15-20 gallons running around the lake a few times. Anyhow, I'd be willing to work out a trade for a nice 225 promax.
Name:	lf front.jpg
ID:	402534Click image for larger version.
  10. #9
    Lake Coochiching, Ontario
    What year is your 200XS? Gen 1 or 2?
  11. #10
    Aug 2015
    Southeast
    2002 so Gen 1.
  1. Gambler
    By fast gambler in forum Hulls larger than 20'
    Last Post: 09-23-2016, 02:20 PM
  2. Gambler
    By fast gambler in forum Hulls up to 20'
    Last Post: 05-28-2016, 02:47 PM
  3. Gambler help
    By RMScatman in forum General Boating Discussion
    Last Post: 09-26-2015, 06:53 AM
  4. help on gambler set up
    By bhasty in forum General Boating Discussion
    Last Post: 12-19-2013, 09:24 PM
  5. gambler set up ?s
    By fast gambler in forum Props, Setup, and Rigging
    Last Post: 03-10-2008, 11:55 AM
