Results 1 to 11 of 11
06-29-2017, 08:28 PM #1
merc black max wont go above 1500 rpm under load
had an issue while back with a motor that would run, idle great then when throttled down, it would just bog slowly at about 1500rpm, ended up being idle control wire was shorting itself out, once I fixed it, she roared, well having same problem with a 135hp, I inspected all wires, fixed a few, even swapped out stator, and still same thing, is possible for idle control module to be bad? i did try unplugging it and same result. where can I go next? trigger? spark, compression etc?
06-30-2017, 07:09 AM #2The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
If idle control module is suspect, completely disconnect it? We actually used to throw them away.
W2F a V-King liked this post
06-30-2017, 04:42 PM #3
I did and it didnt work, gotta be something else. how can I test switch boxes? is there a test for trigger?
06-30-2017, 05:30 PM #45000 RPM
- Jan 2013
- SE MN
- 866
- 44
- 145
- 63
Get yourself a Factory Merc service manual. It will teel you much more than the aftermarket ones will. Usually some on ebay.
stivov1, CHICKENHAWK liked this post
07-04-2017, 12:28 PM #55000 RPM
- Jun 2009
- central minnesota
- 770
- 30
- 24
sounds like its running on either one switch box or at least one carb is plugged or fuel delivery problem.fuel pump diaphragm broken? first do spark test,all should jump 7/16".take air box cover off,run motor,blip open throttles quickly, with finger and look at nozzle in each carb barrel,one at a time. should see a flow of fuel out top of each nozzle.get a spark plug wire pliers and pull each wire off plugs one at a time,its called a balance test.-th
07-04-2017, 11:49 PM #6Member
- Jul 2016
- Bowling green, KY
- 62
i had a similar problem with a black max 200. it ended up being my stator. once i replaced that, she would get up and go....untill i blew her up. However, the stator is what solved my problem.
07-05-2017, 07:41 AM #7
thanks for input guys, it ended up being the trigger, brown to purple had bad reading so replaced it and back up and running now!
07-06-2017, 11:57 PM #85000 RPM
- Jun 2009
- central minnesota
- 770
- 30
- 24
SO IT WAS ONLY Running on 4 cylinders?-th
07-07-2017, 09:21 AM #9
07-12-2017, 07:23 AM #10
ended up taking it back out and started acting up again, I had a parts motor and replaced coils and switch boxes, then it was flying! when got back to dock it died, sounded like it was running out of gas, so IDK, maybe fuel diaphram now? this thing has been a pain in ass!
07-17-2017, 12:20 PM #11
Any updates?
Azure AZ259, 8.1
96 Merc 225 3.0 Saltwater wont power load.
By RedonYellowKillaFellow in forum Technical DiscussionReplies: 18Last Post: 06-20-2013, 11:01 PM -
1996 Mariner 150 wont turn rpms under load
By Orange Rally 150 in forum Technical DiscussionReplies: 4Last Post: 06-03-2007, 09:22 PM -
1978 Merc 1500 V6 Black Max
By the rev in forum Technical DiscussionReplies: 5Last Post: 06-01-2007, 05:59 PM -
windows wont load
By P man in forum Computer and Forum SupportReplies: 6Last Post: 09-30-2004, 10:06 AM -
Wont get over 1800 rpm under load
By shaun in forum Technical DiscussionReplies: 11Last Post: 06-23-2004, 06:41 PM
