Results 1 to 15 of 22
    SW Florida
    Help with hooking up Smartcraft Monitor 2002 300x
    Need help with hooking up Smartcraft Monitor 2002 300x.
    The following pics are my gauge and the two open plugs I see on the motor.
    I found the parts list in my book.
    Question 1: Do I really need this $50 junction box?
    Question 2: What does "Termination resistor on this end" mean? (see pic motor side of diagram) Is this termination resistor part of the harness?
    Question 3: Does Harness 84-879981T-20 have a plug on the end that fits one of the plugs on my engine.
    Question 4: Do I really need the $10 weather cap and Termination resistor cap T-1 on the empty ports on the junction box or can i tape them or silicone them up since I will never need more ports?
    I'm hoping all I need is Harness PN 84-879981T-20. Anyone confirm that this just extends the plug and adapts it to the engine side?
ID:	378923Click image for larger version.
ID:	378924Click image for larger version.
ID:	378925Click image for larger version.
    2004 Hydra-Sports Vector 2600 - twin 225 Yamahas
    SW Florida
    Anyone know? I ordered harness since I was putting an order in anyway. I figure I definitely need that.
    What motor harness do you have? I am guessing old? If so you will need the smart craft harness and a junction block. Terminator on the block also. And a harness that goes from junction block to the tach...
    when i installed the sc1000 on my 1992 superboat w/2001 300x it was gauge with the blue can line right to the motor. No J box.
    If anyone would know for sure, it would be you... I was just looking at the set up in my boat....
    Oh Im no guru just how mine is set up. Did one in a 24 super but put a verado with power steering and fly by wire shift and throttle in that so the j box was needed so eveything can communicate with the computer.
    Oh and the terminator is needed when ever the wire goes no where.
    Apr 2014
    St. Pete, FL
    When i added smartcraft nmea2000 gateway module to my old boat I had the blue cable with yellow resistor ends, and a male to male adapter to bypass using the junction box as I didn't have any other SC gauges, http://www.veradoclubparts.com/CABLE...-892452t01.htm this allowed me to plug the module directly to the harness
    Aaron
    Fountain 38TE, quad 400 Verados
    Talon F20 Flats boat, 250XS
    SW Florida
    I went ahead and ordered the harness the junction box weather cap and Terminator cap. What's another $200 at this point
    May be that some harness's will hook up directly to the tach. I got curious and tried to do that with mine. Wouldn't work.
    I had to send my computer to our Mercury Service rep and have him turn the smartcraft on in my computer. Of course than I had to go thru 120 minutes of break in again
  12. #12
    Western Pennsylvania
    What's the part number on the monitor? I have the old square looking one in my Cougar and it's acting funny... goes blank at times.
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
  13. #13
    SW Florida
    My monitor? It's 79-892219K19
    So I have it all hooked up now and engine rigged and turned the key on yesterday and the Smartcraft doesn't power on. A couple people have told me the think it only comes on with the engine running. I'm not at the point to test run my engine yet. Is this true or is something wrong? Is the power supposed to come through the CAN cable or does it need keyswitch power to the purple wire? The book says the purple and tan/blue stripe wires coming out of the Smartcraft gauge (see letter C in the pic below) are for "depth finder warning horn"
ID:	382455 I get the feeling this thing needs power to that purple....
    Attached Thumbnails Attached Thumbnails 20170801_105902.jpg   20170728_142715.jpg
  14. #14
    I have the older SM and it powers up with just key on. Also gets it power through the SM harness.
  15. #15
    SW Florida
    Sm?
  1. smartcraft monitor kit
    By steve123 in forum Technical Discussion
    Last Post: 10-05-2015, 03:48 PM
  2. mercury smartcraft monitor
    By ckswitzer in forum Electronics, Audio Systems, and Wiring
    Last Post: 04-26-2011, 07:44 PM
  3. Smartcraft Monitor
    Last Post: 03-02-2011, 01:55 PM
