Results 1 to 7 of 7
Thread: temp gauge
06-28-2017, 02:21 PM #15000 RPM
- Sep 2016
- haliburton
- 211
- 10
- 7
temp gauge
I bought a new temp gauge for my 86 175 johnson where would i put the temp sensior on the block?
06-28-2017, 06:06 PM #2
There is a small, flat dimple in the cylinder head near the top. grind the paint off the dimple. Using a "Z" bracket, attach the bracket to an adjacent 1/4" bolt and screw the sender down until it makes good contact. I use thermal paste (the stuff you use on CPU's in a computer) such as arctic ice. Teleflex make a specific sender and bracket for that purpose. The standard sender will give a false reading.
06-28-2017, 06:20 PM #35000 RPM
- Sep 2016
- haliburton
- 211
- 10
- 7
My sender is flat so it will be in contact with the block but where should i put the 1/4" screw? do i have to drill and tap one?
06-28-2017, 06:27 PM #4
jaybrown thanked for this post
06-28-2017, 06:29 PM #55000 RPM
- Sep 2016
- haliburton
- 211
- 10
- 7
ah now i see thank you so much for posting that for me
06-28-2017, 06:32 PM #6
You can also make a place to put the sender in the actual water jacket the same way I discribed adding a water pressure fitting in this thread: http://www.screamandfly.com/showthre...ure-connection
06-29-2017, 10:58 AM #77000 RPM
- Central Florida
- 2,644
- 37
- 32
- 219
That will work but water under that cover is after the thermostat and no pressure so can vary compared to core engine temp. My experience on xflow V6 the best water temp reading is to drill and tap 1/8npt in top of cylinder head just in front of the thermostat. One in each head and two gauges. Or use the thermocouple rings under sparkplugs for cylinder head temp.
Rpm gauge and temp gauge wanted
By ndependent in forum Parts WantedReplies: 0Last Post: 06-27-2017, 08:18 PM -
Mercury Tech: Fuel gauge, temp gauge and tach...
By fierodough in forum Technical DiscussionReplies: 0Last Post: 09-17-2014, 12:22 PM -
1980 BlackMax 200 Water Pressure Gauge and Temp Gauge Installation
By mwidden in forum Technical DiscussionReplies: 2Last Post: 09-04-2014, 05:33 PM -
temp gauge help
By race#115 in forum Technical DiscussionReplies: 3Last Post: 04-14-2004, 08:53 PM
