Results 1 to 7 of 7
    Jul 2012
    st. clair shores, MI
    black max wont power up/ plane out
    I got a 135hp blackmax on a trade, put it on a 18 foot center console, took it out other day and sputtered, and ran like crap, went home and started testing, found out only had spark on 3 cylinders, so traced it to stator, swapped out yesterday and have spark now, just took it out again, and no sputter, runs and idles great, but when down to full throttle, just wont go, pics up a little bit but not much, I have a 13.75 / 21p prop on it, only one I had in the garage, is it possible its too much prop? boat too heavy? thanks for any input
    Could be too much prop. Good easy way to test is to back your boat into the water untill the avatation plate is just touching the water. With the boat fully strapped onto the trailer you can put it into gear and rev it way up to see if the motor will re. The way ya want it to. It will give the mota a load but will suck in air and spinn high enough to let ya know if its running up on rpm
    Jul 2012
    wondering if could be bad idle control module? I did just find a nick in it, maybe was shorting itself out, I think im gonna fix it and relaunch it and see
    Jul 2012
    nope, just got home, same thing, im gonna look for a smaller prop to rule that out
    Jul 2012
    or maybe still stator problem?
    Dec 2011
    Ludington michigan,on the shore
    Trigger arm hooked up?
    Jul 2012
    yes, a buddy of mine swears when under load and wont get above 2000 rmp gotta be stator? how can I bench test it? I have another good known stator on another powerhead, maybe Ill just swap it out and see
  1. 1985 evinrude 150 idles great but wont plane
    By Brian Bownds in forum General Boating Discussion
    Last Post: 09-03-2016, 08:08 AM
  2. Boat wont plane...
    By crankn101 in forum Technical Discussion
    Last Post: 08-26-2013, 09:26 AM
  3. Mercury Tech: 95 mariner 200 efi wont plane
    By Old Skeeter 2 in forum Technical Discussion
    Last Post: 06-18-2013, 11:36 PM
  4. 1983 150 black max hesitation while getting on plane..possible culprit?
    By mercdblackmaxx in forum Technical Discussion
    Last Post: 02-19-2013, 02:31 PM
  5. jet40 wont plane
    By eightpt in forum Technical Discussion
    Last Post: 07-30-2004, 09:36 PM
