Results 16 to 30 of 68
Thread: Core matt any one ??
06-27-2017, 07:52 PM #16Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
we all know the danger of long term styrene exposure, lol
06-27-2017, 08:23 PM #17Member
- Jun 2017
- LI
- 57
You guys are funny
06-27-2017, 08:57 PM #18Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
06-27-2017, 08:59 PM #19
06-27-2017, 09:34 PM #20Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
06-27-2017, 10:10 PM #21Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
06-27-2017, 10:19 PM #22Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
Ok back to the plot.
I was going to say coremat good to use on small molds as in i can carry it.
I have never made anything big.
So should we view it as a core or cloth?
Does it get used rather than foam in thin cores?
06-28-2017, 12:02 AM #23
sound like you better find all the core matt manufacturing sights on the net and do some reading ! Its a CORE that's a MATT !!
Matt is not the same as fabrics ?? have used thick core matt during the making of big moulds up to 40 foot Hulls and decks and two thick layers separated by fabrics and csm over under and between never use woven glass for anything !! has a thousand uses! and new uses keep coming to light all the time ! BUT THERE ARE PLACES IT SHOULD NEVER BE USED !Last edited by tunnels; 06-28-2017 at 12:06 AM.
06-28-2017, 12:20 AM #24Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
I think woven is dead in large weights, its all stitched fabrics now as far as I can see
06-28-2017, 01:55 AM #25
06-28-2017, 02:03 AM #26
Yes !! has had its had its day that's for sure and is 9/10 of the problems because builders still cant think past it !! trying to change attitude's is like push ice up hill with a sharp stick on a hot sunny day!! .
AND stitched fabrics don't use binder so can be used with any and all resins!
Manufactures are 10 steps ahead of us flatlanders But there are still die hard's within the ranks that still stick to there age old stories and wont or don't want to hear other wise !Messing round with boats is fun !! the learning never stops ,even after more than 30 years there's always something new happening somewhere ! BUT somethings never change and some problems never go away and just keep reoccurring !!so moved into Composite Forensics , Now that something completely new !!
06-28-2017, 02:15 AM #27
Have you tried vacuuming core matt? its been happening for at least 10 years that I can think of !!
Some is made specially for infusion and is manufactured in a way to be a flow medium as well so have the best of both worlds with a flow medium between the glass layers ! or as my son uses between layers of carbon so resin flow is inside between and flows out through the carbon ,is quick and easy and to improve the micro pin holing that can be experienced doesn't use full vacuum any more and problem solved !!
I have always asked this question How much suck do you really need to infuse with ??Last edited by tunnels; 06-28-2017 at 02:20 AM.
06-28-2017, 02:25 AM #28Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
Suck it and see?
I have seen guys doing test panels whenever anything changes in there layup so i guess they also test vac and then test the panelLast edited by powerabout; 06-28-2017 at 02:54 AM.
06-28-2017, 02:28 AM #29Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
Re the woven
If j was building anything boat wise other than an engine cowl, i would be consulting a composite engineer to do a fea on it and also spec the layup.
I have seen a few guys who have been doing hi tech stuff for years be amazed when somebody like those clever kiwi guys from High Modulus who now work for gurit i think, redesign it, stronger lighter and easier to build in most cases and that usually means cheaper and faster to build as wellLast edited by powerabout; 06-28-2017 at 02:35 AM.
06-28-2017, 02:38 AM #30
Yip suck it and see is all you can do in so many cases !
But with a problem I experienced long time ago I was astounded at just how little suck was actually needed to solve the problem we had ,like 1.5% of ultimate suck was all that was need ,so that's 1.5% of 14.7 psi and it was perfect in every way !!
I even had samples sent to the Auckland university engineering department to verify what we had done !
I even made a DVD video of the whole process from start to finish and gave it to the resin manufacture that supplied all our materials at that time !Last edited by tunnels; 06-28-2017 at 02:41 AM.
Is it possible to forgo balsa core and glass in multiple layers of 18oz matt?
By ernstudet22 in forum Fiberglass and Composites DiscussionReplies: 114Last Post: 11-30-2007, 05:04 PM -
Matt the Catt
By Dave@DunnWright in forum General Boating DiscussionReplies: 16Last Post: 08-14-2004, 04:53 PM -
Matt Daggett
By Dave@DunnWright in forum Technical DiscussionReplies: 0Last Post: 02-24-2003, 09:04 PM -
Matt, Mark
By Scream And Fly in forum General Boating DiscussionReplies: 0Last Post: 11-01-2001, 10:01 PM -
Matt s pics from firewater
By HAZMATT in forum General Boating DiscussionReplies: 1Last Post: 08-31-2001, 11:48 PM
