Results 1 to 4 of 4
    Feb 2011
    South Florida
    HELP.....Johnson V8...How do you know if it's a 4.0 Litre Block
    There are no serial number stickers on the engines. The FREEZE PLUG #0433002...how else can I find out if it's a 4.0 Litre Block...???
    Singapore/Melbourne
    part of the head gasket sticking out at the top by chance?
    if it has finger port bosses its a 4.0 but that was later ones
    3.6 had twin pack ignition ( but that could of changed)
    I think a dealer can run the serial number
    Jul 2002
    Las Vegas, NV
    Pull a spark plug and look down the bore. Rotate the FW until you can see the piston edges. 3.6's used a flat top piston. 4.0's had a domed piston. You can see the dome start about 1/4" or so from the edge of the piston.
    Keith-
    Jul 2002
    Las Vegas, NV
    This thread had a good bit of info: http://www.screamandfly.com/showthre...ning-Year-Help
    Keith-
  1. Merc 2.4 litre block
    By PUDDLEMAN in forum Technical Discussion
    Last Post: 10-15-2015, 12:21 PM
  2. 2.0 Litre block
    By dez nuts in forum Misc. Parts and Accessories
    Last Post: 07-01-2014, 09:49 AM
  3. Mercury Tech: 3 litre block porting
    By crimeinc2 in forum Technical Discussion
    Last Post: 10-07-2012, 07:21 AM
Spinelli Props
