Results 1 to 15 of 27
    Prince George B.C. Canada
    20inch Bass Mid section drilling holes?
    My question is what is the purpose of drilling 4 holes the two on each side you see on some 20 inch bass mids just below the exhaust tube? Two 1/4 inch holes on each side on those two parts that stick out? Reason im asking is my new mid doesn't have them drilled but my old one was. Should i drill or not, any benefit or Loss? 225 promax.
    The holes on my old one are were I have circled in white. What will drilling some holes there do? anything? Click image for larger version.
    Dec 2011
    Mobile, AL
    if the can is still in the leg it wont do much at all, if its removed you get a little more sound out of them at idle, on the older motors that was the idle exhaust reliefs but on the later style it don't do anything other that what the little hole on the port side with the rubber boot on it does
    Allison xb 2003, 280 ROS
    Mar 2010
    houston, tx
    Exhaust breathes a little better and dumps water a little faster out of the can on holeshot.
    All my 20" are that way
  4. Likes whipper liked this post
    OK thanks my 225pm is a 96. Ive debated taking the can out? How much louder would it be with can out? no performance benefit i would imagine. my power head is off right now changing the adapters so now would be the time to do it. Would it effect cooling at all? Do you simply just remove the can thats it? Gaskets and everything line up wont effect water pump ect...?
    Sep 2008
    louisville
    Just look at your old can and do the new one the same way ?? It'll be fine .
  7. Likes whipper liked this post
    Ya thanks thats what I was thinking also Paul. dinner time. :] Just thinking i might like the exhaust sound without the tube in there wonder if there are other things other than just taking it out i would have to do?
    Sep 2008
    louisville
    It just sits in there , pull it out and lighten it up some ! Drill the bottom of the can too if you want . It'll only sound better ! The old mod v p motors came like that !
  10. Likes whipper liked this post
    Dec 2011
    Mobile, AL
    the can helps keep the heat from the exhaust off the leg, i have seen the paint blister on one, and the paint usually keeps a haze to it, but with the can removed and the bottom drilled it sounds bad azz
  12. Likes whipper liked this post
  13. #9
    im having trouble finding some pics were to drill the holes at the bottom of the can? Found lots of threads no pics! haha Im working on it now going to remove exhaust tube and drill bottom. lol What the heck. ill try it. Push comes to shove i can always put the tube back.
    http://www.screamandfly.com/showthre...haust+drilling
    Best thread ever!! Im just doing the 5 hole thing each side can out. i did do the 2 smaller holes in the two spots under the exhaust tube tonight like my other one.
    all done just have to put the power head back on. Can out forgot to take a pic with all 10 holes and cleaned up and i could have done a better job being in a straight line!! LOL Also did the back holes were my other mids holes were Click image for larger version.
ID:	378796 Click image for larger version.
  16. Likes Slimm liked this post
    Mar 2011
    Virginia
    You're going to love the sound....the neighbors, not so much
    Go Time
    26 Regulator twin 250 EFI
  18. Likes whipper liked this post
  19. #13
    Ya those BB boats open there cut outs all the time. i love that but I love the 2 stroke sound cant wait to hear it maybe today.
  20. Likes pkstv liked this post
  21. #14
    Apr 2017
    pa
    5 Post(s)
    I already have the ten holes at the bottom of my mid. I thought about drilling out the upper ones, but afraid to. I can run my hyd jack down and quiet it down a little if need be. Cant really quiet those upper holes.
  22. #15
    Apr 2017
    pa
    5 Post(s)
    Im talking about idle only ofcourse
  1. OMC Drilling holes in the mid
    By Captain75 in forum Technical Discussion
    Last Post: 04-24-2013, 08:46 PM
  2. Drilling holes in cowling.
    By tmouhalis in forum Technical Discussion
    Last Post: 07-17-2010, 08:30 AM
  3. Drilling vent holes
    By hotbeek in forum Technical Discussion
    Last Post: 04-18-2009, 08:42 PM
  4. drilling holes
    By screwedbayou in forum Props, Setup, and Rigging
    Last Post: 10-15-2008, 11:25 AM
  5. Drilling holes...
    By rross in forum Fiberglass and Composites Discussion
    Last Post: 12-11-2006, 09:49 PM
