Results 1 to 6 of 6
Thread: Merc xri 2.5 150hp
06-25-2017, 11:45 AM #1
Merc xri 2.5 150hp
Looks like I might be buying a merc xri 2.5 150hp, I want to convert over to carbs, can I put 200 carbs on 150 and change the intake over , the block is a 2.5. also what are the differences between the 150 and the 200. thanks
BLAZER BAY 2400 SUZUKI 250 4 STROKE
18FT ASTRO BASS BOAT 200 MERC
06-25-2017, 12:00 PM #2
Why on earth do you want to change it to carbs? The xri performs better.
Can you put 200 carbs and intake on? Yes, will it make much of a difference? No not without changing more stuff.
If you want more power the best think to do it change the tuner one from a 200, I like the 2.4 200 bell tuner the best on those motors. Cut the heads to 34cc, slap some reeds in it and go.
06-25-2017, 12:57 PM #3
Guess I'm a old fashion carb guy, easier to work on.
06-25-2017, 01:23 PM #4
But there is no gain really in your application.
I have 6 v6 mercs 3x 2.4 carb, one 2.0 carb and 2x laser style injection(what's on an xri) the laser injected motors are a lot more trouble free over all.
The stock carb motors are pretty trouble free but not as much as the injected ones.
Injected starts easier, gets better mileage loads up less idling on and on and on.
06-25-2017, 02:09 PM #5
Guess I'm not to familiar with efi's, I'll give it a try!!!
06-25-2017, 02:18 PM #6
2.4 merc 150hp
By mouse4x4 in forum Technical DiscussionReplies: 2Last Post: 05-12-2014, 03:59 PM -
Evinrude E-TEC 150hp DI vs Latest Mercury 150hp 4 stroke
By LIQUID NIRVANA in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 35Last Post: 02-07-2013, 08:18 AM -
150hp xr2 vs 88 merc 200 hp
By fergie72r in forum Technical DiscussionReplies: 1Last Post: 07-02-2012, 05:09 PM
