Results 1 to 3 of 3
Thread: question on 2.5 crank
06-23-2017, 04:00 AM #15000 RPM
- Jan 2005
- michigan
- 178
- 26
- 7
- 15
i have a question on a 2.5 crank when they say small bearing crank what exactly are they referring to the top bearing or the center mains or bottom bearing . and whats the difference in diameter from small bearing to large bearing cranks . if its in the upper end can you run a small or large bearing as long as you use the same end cap it was made for on the same crank. so what i am asking is the diameter of the end cap the small or large bearings the same to use in any block or are the blocks different to except them. the reason i ask is i was told i have a small bearing block and wanted to see what was enter changeable or what to look for. thanks for any help .
06-23-2017, 05:24 AM #2
big bearing usually (by most) refers to a big ball bearing similar to one on tha bottom of tha crank.. only used on high performance '98 and above 260/280/300 blocks...
tha other two are usually referring to "crank journal" size of "production" motor top bearing.. some seem ta call tha larger "journal" a big bearing not knowing tha difference.. just tha way wording has played out over tha years.....
06-23-2017, 11:04 AM #35000 RPM
- Jan 2005
- michigan
- 178
- 26
- 7
- 15
appreciate the info thanks .
2.4 - 2.5 crank question
By Seacraft20 in forum Technical DiscussionReplies: 25Last Post: 04-17-2015, 08:06 PM -
Mercury Tech: 260 crank question...
By h2oskiier30 in forum Technical DiscussionReplies: 4Last Post: 11-20-2008, 12:58 PM -
2.4 crank question
By riverrocket900 in forum Technical DiscussionReplies: 0Last Post: 07-24-2007, 07:34 PM -
2.4 crank question
By stvmike24 in forum Technical DiscussionReplies: 1Last Post: 07-23-2007, 05:18 PM -
2.4 crank question
By Burke Kilgour in forum Technical DiscussionReplies: 14Last Post: 10-15-2001, 11:13 PM
