Results 1 to 3 of 3
Thread: Head gasket choice
06-22-2017, 11:49 AM #1
Head gasket choice
I have twin 88/92 open deck 225 V6's. Current compression is 70/75. I'm going to replace the 809 head with the 2.7 (shallow death) heads. can I safely use the thinner 93 & up head gaskets or is it better or use the stock thicker gaskets.
06-25-2017, 06:31 PM #2
Yes u can use the closed deck head gaskets Bolt head on with out. Gasket spin motor around by hand if it don't hit the head. Your good to go with closed deck gasket
Nitrous is like a slut. u wanna hit it but you know there will be consequences.
06-25-2017, 10:31 PM #3
Thanks
head gasket and cylinder head
By drtyTshrt in forum Technical DiscussionReplies: 1Last Post: 03-26-2017, 08:47 PM -
OMC Tech: Head Choice & Stock CC's
By Jim_Pat in forum Technical DiscussionReplies: 11Last Post: 09-17-2013, 07:03 PM -
OMC Tech: Head Gasket Choice
By Jim_Pat in forum Technical DiscussionReplies: 0Last Post: 06-16-2011, 04:17 PM -
head gasket
By jmr112 in forum Technical DiscussionReplies: 0Last Post: 01-16-2002, 01:05 PM
