Page 1 of 17 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 1 to 15 of 248
    Aug 2009
    mpls,mn
    birth,rebirth or afterbirth of a 12 inch v-4,v-6 crossflow omc mid
    Anybody care? just done one with full docs,& pics what a *itch .Sure theres been many done before.
    Of course I care ..... I have an edge as I know your work WELL!!!! Bring'em on bro as now ya gut me wound! Gary
    Bismarck ND.
    I'd like to see it as well
    Galveston County,TEXAS
    yes please
    limited skills
    Miami,Fl
    Count me in
    Aug 2009
    mpls,mn
    Ok so this is going to be hard [pics the biggest problem] so bear wit me.I said last year if I came across a free mid I would try a 12 inch mid so here it is IT JUST BARLEY WORKED.Started with a 1996 60 degree mid can the same as older ones just a little different.Cant use the swivel or clamps steering arm and upper mount way different.
    Aug 2009
    mpls,mn
    stocl height is 17 1/4 tall so marked out 8 inches and sawzall it just short so machine shop can mill both pieces flat.
    Aug 2009
    mpls,mn
    more pics
    Aug 2009
    mpls,mn
    pics are a problem or im the problem.
    Aug 2009
    mpls,mn
    pics im using a swivel and clamp from a 1986 v-4
    Aug 2009
    mpls,mn
    cut off 7 3/4 off steering arm, tuner now 6 inches cut section off swivel bracket.mid now 9 1/2 tall with adapter 12 3/4 tall
    Attached Thumbnails Attached Thumbnails IMG_1675.jpg   IMG_1676.jpg   IMG_1677.jpg   IMG_1678.jpg   IMG_1679.jpg
  12. #12
    Aug 2009
    mpls,mn
    gotta go work be back later ken out.
  13. #13
    Aug 2009
    mpls,mn
    The bottom of the swivel brackets last 1 1/2 only fits the steering arm diameter higher than that it gets bigger so I cut the end off to make a 1 inch block to bolt and weld back on.When I make 15 inch mids I can get 4 recessed 1/4 20 cap screws to bolt it back on the swivwl bracket with the 12 inch I can only get two screws so I have to weld it also.
  14. #14
    Aug 2009
    mpls,mn
    pics of the end of bracket,when I cut it off I need to cut the bottom of it off also cause its not flat so I loose the rubber seal part on the end.
    Attached Thumbnails Attached Thumbnails IMG_1692.jpg   IMG_1693.jpg   IMG_1694.jpg   IMG_1695.jpg
  15. #15
    Aug 2009
    mpls,mn
    bottom of bracket only room for two bolts no big deal have welder.
    Attached Thumbnails Attached Thumbnails IMG_1701.jpg   IMG_1700.jpg   IMG_1703.jpg
  1. The Rebirth of a 30' Velocity Race Deck
    By NJSBOAT in forum General Boating Discussion
    Last Post: 06-04-2020, 11:56 AM
  2. absolute disaster..pain..rebirth
    By bobbowobbo in forum Fiberglass and Composites Discussion
    Last Post: 07-10-2008, 02:50 PM
  3. omc v-8 rebirth ?
    By CALVINPARKS in forum Technical Discussion
    Last Post: 02-22-2004, 04:46 PM
