Results 1 to 2 of 2
Thread: Prop help
06-20-2017, 10:20 PM #1Junior Member
- May 2012
- miami
Prop help
Hello, I have a hewes lt20 with a 1994 Yamaha 200 pro v, the boat is a bit bow heavy, what prop would u guys recommend? I'm currently running a tempest plus that was originally a 23p and now is 21p, it's been cupped and raked, boat still doesn't ride right, no top end speed and my Roma are running higher than my actual speed for example if Roma r 4500 my speed is around 38mph.
yhanks for ur help!
92hewes liked this post
06-22-2017, 12:14 AM #2Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Lot of times when you de-pitch props they lose their correct blade shape. Try and find an original 21 pitch tempest and give that a shot. A yamaha M21 3 blade is a also a good prop for your hewes. It should get you closer to 1 mph per rpm.
CHICKENHAWK liked this post
OMC Tech: Help! 225 carbed Johnson melting prop hubs / high exaust temps through prop hub
By Tunnelvision1995 in forum Technical DiscussionReplies: 7Last Post: 09-12-2017, 08:03 PM -
Prop slip on overhub prop related to no exhaust relief?
By B.Mac in forum Technical DiscussionReplies: 7Last Post: 10-06-2015, 03:25 PM -
Performance Prop ,ET, Yamaha or Hydromotive 4 Blade Prop ???
By DonChicho in forum Technical DiscussionReplies: 6Last Post: 12-20-2002, 10:49 AM
