Results 1 to 15 of 17
06-20-2017, 07:31 AM #1
Parting out 1993 2.5 245 and late 80s Bridgeport both fresh water. 2 CLEs
1993 Mariner 2.5 245 partout (FRESH WATER ONLY 2nd OWNER):
2.5 Flyweel cover with hardware nice piece no cracks - $50 SALE PENDING
2.5 Single Ram Offshore Clamp/Swivel/Ram with pin/yolks (Mariner Silver) $400 (clamp isn't apart yet here is a pic)
2.5 Exhaust Adapter with tuner - $600 PICS COMING
20" Driveshaft Housing: Bass/Sport (non offshore) Mariner color 20" bass mid housing) - Factory exhaust relief holes above anti cavitation plate, has a very fine little hair line near the upper stbd. edge that I really can't tell if its just in the paint but it hasn't changed since last year. Comes with solid mounts and plastic mount covers.[B] $150 + SHIPPING
20" Shift shaft assembly with arm. - $40
Late 80s 2.4 Bridgeport: (MOVED TO NEW THREAD)http://www.screamandfly.com/showthre...68#post2967568
THE FOLLOWING PARTS ARE SOLD:
2.5 Block/Front half was very nice has two cylinders now that need renik'd (piston pin let go on # 3 and ring seized it to the exhaust port, heat markings in exhaust chest) # 1 scored minor. no welds. I'm thinking. $550 to your door. SOLD
Throttle Lever Assembly $75 SOLD
Trim pump/alum bracket nice piece $175 SOLD
Stock 245 Flywheel - $350 very clean perfect magnets - SOLD
Mariner Cowl pan and skirt $600 - SOLD
Big bearing crank journals are all smooth no damage good shape - $600 - SOLD
Cowl Top Pin/Bracket/nut - $100 SOLD
Carbs, Manifold, 4 pistons/rods SOLD
Stator, Trigger, Switchboxes, bracket - SOLD
(2) Starters $100 ea. SOLD BOTH
Set of stock 2.5 245 heads, SOLD
Big bearing top cap / bottom cap SOLD
Mariner CLE - SOLD
2.5 carb Air Box - $50. SOLD
20" 4 hole 1.87 CLE ASKING $700 SOLD
This CLE was my spare never ran it looks like a good piece, carrier is pinned water pump included but suggest inspect or replace. There is a plug screw in the top side of the bullet bulge, I don't know why, (see photos). Looks like torque tab was added (rivets show). PHOTOS:
2004 Hydra-Sports Vector 2600 - twin 225 Yamahas
06-20-2017, 11:58 PM #2
I'm interested in the 2.5 245 carbs if you have them let me know. can be reached at 1-757-406-4612
thanks, Bryan
06-21-2017, 04:56 AM #3
06-21-2017, 04:38 PM #4
mariner cowl any pics and how much thank john
CRAZY FAST JOHN
06-21-2017, 04:52 PM #5
Cowl and Pan and Skirt asking $600 plus shipping (hope you can pick up). Can separate pics here. http://s1382.photobucket.com/user/at...r%20245%20Cowl
Cowl has a 3 way crack just above Mariner decal from a flying engine part years ago.2004 Hydra-Sports Vector 2600 - twin 225 Yamahas
06-21-2017, 11:15 PM #6
Let me know if deal falls through I'll take carbs
thanks
06-23-2017, 10:36 AM #7
The Bridgeport nik or steel?
'95 STV "The Blue Goose"
06-23-2017, 11:52 AM #8
Not sure hope to make time to pull the heads off today and start tearing that engine down. I'll let you know asap
06-25-2017, 07:03 PM #9
06-29-2017, 07:56 AM #106000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
I am interested in BPort pistons and rods,at least 1 good port and 1 good stb. tks.,where in NY ? I will give you $500 for that ole cle in your pics,really only interested in the guts/shafts for spares,the case..... is well,not for my boat,I have already coned CLE cases setup for my Ally,,tks
06-29-2017, 08:35 AM #11
I'll pm you address. Bridgeport appears to be Nikasil. Pulled heads off yesterday. Weak magnetic pull just like my 2.5.
06-30-2017, 08:23 AM #12
Heads off the 2.4, it Looks like nikasil. Crosshatch and weak magnetic pull like my 2.5 block. There's what looks like wear right where the bridges are it's not dull like the nikasil. I assume that's normal because the rings wear differently at the bridges. Cant catch a fingernail on it it's smooth. 120-123 psi on all 6 before it was removed from a viper that did 103 with this motor.
07-01-2017, 11:04 AM #136000 RPM
- Dec 2011
- Ottawa
- 1,365
- 33
- 47
- 20
- 72
So is the 2nd cle pending sale on my offer ? I mssg'd you and wondered if you got em ? My shipping is 13669 NY , tks
07-01-2017, 01:13 PM #14
I'll pm u in a few but no buyer is I'm SC
07-03-2017, 09:21 PM #15
I gave the CLE buyer till Wednesday. I changed the gear oil and boxed it up today. If the deal falls thru it's ready to go. $750 to your door in the Northeast. So check back Wednesday morning whomever is interested in the CLE
30velocity thanked for this post
Fresh water Mint Mercury Bridgeport 1 Piece Adapter
By scottistang in forum Misc. Parts and AccessoriesReplies: 1Last Post: 05-09-2016, 05:45 PM
