Results 91 to 105 of 130
Thread: Mercury in line 6 hop ups
07-10-2017, 06:41 PM #91Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Awesome
07-10-2017, 06:54 PM #92Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
Hi Mark 75
how do I get the cylinders further apart and use the same crank?
07-10-2017, 06:55 PM #93Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Noticed that. Where are the specs , did he reveal?
07-10-2017, 07:02 PM #94
mrcrsr liked this post
07-10-2017, 07:34 PM #95Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
07-10-2017, 07:37 PM #96
07-10-2017, 07:42 PM #97Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Centreline of cyl to centre of crank pin. Factory crank pin spacing is not staggered as new block is. I believe that's the question, unless he used unequal wrist pin spacers. But then I'm not on as desktop so I could be seeing anything lol
07-10-2017, 07:49 PM #98
I thought the question was how did Christner get looper porting on a Merc crank when it won't fit on a Merc block. The answer is he did not use a Merc block. Same for Mr. Austin. Its looper porting with a Merc crank, not Merc block. The porting layout is entirely different, the mixture flow path thru the motor is entirely different.
07-10-2017, 08:17 PM #99Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Of course it's looper. But one pic of the block with porting looks as if the cylinders are grouped in pairs with greater space between pairs than cyl in group giving rise to what crank would accommodate this. Perhaps it's only the pic
07-10-2017, 08:25 PM #100Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
07-10-2017, 08:34 PM #101Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Ahhh, I know. Either way where are the keys! The other thread I think someone asked if he ever built ex chests for it. Sweet looking engine.
07-10-2017, 09:46 PM #102
The picture of the two blocks together, the smaller one is the 66 ci block and dick's block is based off the 99 ci block.
07-11-2017, 02:38 PM #103
What's the better carburetor to use? Assuming your not building a motor from scratch.
Wmk-9 wmk-19 ect...
07-11-2017, 08:47 PM #104Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Will that adapter take a TC or those adapters still around. Thought someone was making them? Bolt on three TCs from a CHRYSLER if you can't find Merc. 44.5mm 1.75" throttle bore and 41.3mm 1.625" venturi
07-11-2017, 09:06 PM #105
All the carbs I have are ~1.25 / ~1.400 they all look similar but have subtle differences.
Mercury 2.5 fuel line
By STELLIX in forum Technical DiscussionReplies: 2Last Post: 04-21-2017, 05:57 PM -
Mercury in line C blocks
By Tom Smyth in forum Technical DiscussionReplies: 17Last Post: 09-22-2015, 07:38 PM -
mercury in-line 6 150
By panhauling in forum Technical DiscussionReplies: 2Last Post: 08-19-2010, 07:58 PM -
mercury 115 in-line 6 firing help
By Javelin409B in forum Technical DiscussionReplies: 8Last Post: 05-22-2008, 01:59 PM
