Results 76 to 90 of 130
Thread: Mercury in line 6 hop ups
07-09-2017, 09:32 AM #76
07-09-2017, 10:38 AM #77Screaming And Flying!
- Miami,Fl
- 6,990
- 128
- 80
- 1269
- 368
Dave S built me an inline 6 that was a hard runner. I never really learned all the mods he did but it was a bear. I only ran up to 6k for I wanted it to live and it did beat on it for 7 years now I have a v4 xflow 140 and this thing is a bear but I know not what has been done inside only the mods I have done and it is alot more than the inline I had. Cool factor I will give you W2F
07-09-2017, 10:56 AM #78
Did he change anything with the combustion chamber in the block when he converted it to a looper? I remember it had a weird shape that was similar to the piston crown but reversed. It would be interesting to mill the existing head off and go with something like a hemi shape, but unsure if there is even enough meat in the block to install studs and have a gasket surface.
07-09-2017, 03:15 PM #79
Sam knows a lot more about the Quincey Loopers but I've always thought they started from scratch with a total redesign if the block.
07-10-2017, 06:58 AM #80Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
07-10-2017, 07:28 AM #81Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
07-10-2017, 08:57 AM #82Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Not too long ago a video and description was posted, can't find it either. I liked and posted on these threads, can't find it.
07-10-2017, 09:55 AM #83
07-10-2017, 11:13 AM #84Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Beauty
07-10-2017, 03:09 PM #85action mobile marine, 772 528 0754, dealers for aces fuel products,wolf efi, pro marine,latham and gaffrig/livorsi. we build gearcases and modify them(3 litre) to ratchet, and powerheads as well. 21 skater/3 litre wolf efi 113 mph the engine build http://www.screamandfly.com/showthre...-3-litre-build
07-10-2017, 03:41 PM #86Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
What's the biggest bore and stroke that fits in an L6, someone had to have made an attempt? Custom custom custom, maybe a prototype Lake X motor?
07-10-2017, 05:14 PM #87
Not at all. All the Looper uses is a Merc crank and ignition. Early Loopers used Merc fronts, but later on they had their own dedicated front.
The Merc factory block has the cylinders spaced too close together to convert to loop charging, that's why Christner made his own blocks.
A hemi head on a cross flow is very dificult to pull off. McCulloch did it on their racers in 1963-64, but I have not seen any attempts more recently. You couldn't use Direct Charge pistons, you'd have to use pistons from a 125 and reshape them to agree with your custom hemi head.
On the smaller displacement 6's where they bolted a head on, I'm pretty certain they cut the block back to expose the cylinders, shaved the aluminum off, and fashioned a girdle base around the iron sleeves, then welded the girdle to the sleeves. This is what the head bolted to.
mrcrsr liked this post
07-10-2017, 05:32 PM #88
07-10-2017, 05:55 PM #89Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Capt could you post the link, maybe the video is in the thread? I recall it running on a trailer, first start I think.
07-10-2017, 06:07 PM #90
I have most of the build pics saved, when I get a minute I'll copy them back off of photof*cket
Mercury 2.5 fuel line
By STELLIX in forum Technical DiscussionReplies: 2Last Post: 04-21-2017, 05:57 PM -
Mercury in line C blocks
By Tom Smyth in forum Technical DiscussionReplies: 17Last Post: 09-22-2015, 07:38 PM -
mercury in-line 6 150
By panhauling in forum Technical DiscussionReplies: 2Last Post: 08-19-2010, 07:58 PM -
mercury 115 in-line 6 firing help
By Javelin409B in forum Technical DiscussionReplies: 8Last Post: 05-22-2008, 01:59 PM
